HELP! Advice needed on electrical connection for DRLs...
Hello..
I'm planning to add some DRLs and have most of the wiring figured out except that I need verification for one connection (#30). Let me explain what I have thus far. I have a 5 lead relay and here is my planned connections with the pins:
#85: ground (-)
#86: low beam (+)
#30: ? (+)
#87A: DRL (+)
#87: not connected
The ideal scenario is that the DRLs will come ON when ignition is switched ON and OFF when I switched the headlights ON. Also, would like the DRLs to be OFF when switched to ACC (as I don't want the lights to be on while I'm parked with the engine off and radio on).
I need clarification on where to hook pin #30 for a (+) source. I checked out the cigar lighter fuse and there's power still on ACC. Thinking about the ELEC. IG or IG. COIL fuse to tap into at the fuse box. But, I don't want to short anything out or be stuck if the fuse shorts either.
Any advice would be greatly appreciated or feedback if I have the wrong set up for what I want. Thanks in advance! rudy
www.aftershockproducts.com
