- I wrote to the ebay guy (resk123) that wrote that today to ask him some more questions...awaiting reply.
- I've also written to the ebay REBUILD guy 3 times now, with pics, sent these latest pics of the innerds,
and referenced the Isuzu Workshop Manual, page 5A-5 which says this:
General Service Precautions
The following are general precautions which should be
observed when servicing and diagnosing the Anti-lock
Brake System and/or other vehicle systems. Failure to
observe these precautions may result in Anti-lock Brake
System damage.
The EHCU and valve block connectors should never
be connected or disconnected with the ignition “ON” .
EHCU of the Anti-lock Brake System are not
separately serviceable and must be replaced as
assemblies. Do not disassemble any component
which is designated as non-serviceable in this
Section.
...here's his response today:
Hi Sue,
We have several thousand of this same type abs Module, This Design is used on many other Makes and Model Automobiles, We will have no problem rebuilding this abs Module.
Thank You
Don
Sounds promising.....
Aren't both units sealed? The plastic electronics "brain+solenoid" component should not have any interaction with brake fluid. The brake fluid should be contained inside the valve box. if you look at the picture of the unit split into its two components, you don't notice any brake fluid at the interface of the two parts.
Needs More Cowbell
Carter Pewterschmidt
Did anyone do this and tell us whether it worked?
Scott
Oops, been busy, haven't had time to do it. Maybe this weekend...
Just wondering, has anyone actually confirmed the above is true? When the two sections are "easily" detached, there is no fluid leakage or anything else coming out. I suppose the past photos being referenced which could have been taken after pieces were cleaned up a bit(?).
Well my light just went on when I pulled into a parkiing lot. Can't tell, but brakes seem fine. Gonna check the fuse in daylight. I wonder how hard it would be to just replace the whole ABS system with another from some other vehicle. Heck they are even putting corvette ABS in hot rods now.
You would need a 4WD system - it has double the valving for the sensors.
Wha? We've got the el cheapo three channel unit (Bosch 5.4). Corvettes got 4 channel.
leonml, by whole unit if you mean the hydraulic part as well as the EBCM then it would be a lot of effort for probably no reason. The hydraulics hardly ever fail. It's a pain to bleed if you replace the whole thing compared to just replacing the electronics which is almost always the problem. Unfortunately you can't just get any Bosch 5.4 EBCM and use it on a VX. The electronic brake control modules are vehicle specific. Sure it might fit, but the logic flashed into a Dodge Durango's Bosch 5.4 ABS module will be different than what's in our VXes because the brakes, vehicle dynamics, etc are totally different.
To deal with most electronics module failures is quick, relatively cheap and easy though - it's just six torx screws, two nuts and two connectors. Five minutes to take it off, a few more to put it in a box and ship it off to the rebuilder, five minutes to put it back on the vehicle, done. Takes less than 20 minutes and less than a hundred dollars out of your life and you don't have to see that ABS light any more. And then you can pull a trailer without sweating about how bad you're going to jackknife when that bluehair in the Riviera pulls out in front of you!
Yes - unfortunately my ABS control module had to be repaired. I think I jinxed it. Had been talking (OK it was more like bragging) to a friend about how the VX was 11 years old and had over 114K miles on it and not even a single light bulb had burned out yet. As usual, retribution was swift. The ABS light came on the next day just to prove ALL bulbs were still working.
So - the ABS control module was the first electrical item to go out on my VX, other than the CD changer, which suffered an untimely death at the hands of the kids. And the wimpy OEM speakers which got a little too much Boom, Boom, Pow one day - also a kid-related death. Hmmmm... maybe Sue should add a question to her "sellers list " regarding whether or not you haul children - they seem to significantly increase the level of entropy levied on a vehicle....
