I wanna solder /connect two 18ga wires together but apparently I'm missing something important. I've watched videos & read instructions so I have learned to:
* hold the soldering iron against the bottom the wires
* let it heat 'em up
* hold the solder on top of the wires and let it melt down through.
My "practice" result: Nuthin'.
I'm using thin (fine) 60/40 rosin core flux. Is the cheap, $15, 25w/750 deg soldering iron just a "hello kitty piece of junk"? Do I need to upgrade to something stouter?![]()
