Hi
Just the other day my vehicross started idling between 2000 and 2500.
I cleaned the mass air flow sensor and changed the TPS and cleaned out the EGR. With no change, VX is not throwing any codes. About a month ago changed the FPR and ICV. If you start with the MAF unplugged will not stay running idle is to low. Fuel filter is old, could that be it or is there a way to test the MAF sensor? And where is the power steering presure senor I read about in some old treads causing high idle so I can cross that off the list of causes.
Thanks Steve
