Results 1 to 14 of 14
Thread: radiator problem?
    1999 silver 1346
    radiator problem?
    I have a previous post called overheating is back which discusses in detal my overheating problem but its getting kind of long and i have a specific question now.
    in a nut shell this is my symptom and what i have done.
    My car overheats on the highway, the hotter the day the faster it overheats, also the harder i drive the faster it overheats, if my car is warmed up like 5-10 mminutes i can last like 2 exits on the higway at 70 mph berfor it goes to the H line on a 95 degree day
    this is what i replaced, thermostat 4 times including the last one being a OEM, cluthch fan, upper hose, radiator cap.flushed the system thouraly 3 times, heater core and water pump replaced around 50,000 miles ago and doesnt make any noises and was told by mechanic it was good.
    Here is my question, the mechanic is now telling me it may be the radiator, is there definate test to determan this? I am tired of all the guessing
    thnks
    Mar 2006
    2001 FOXFIRE 0579
    If you are not Loosing coolant, I would think radiator ......considering you have pretty much covered everything else! (other than head gasket, which you would be Loosing coolant)
    Have you EVER used a stop leak product???? If so, it may have stopped more than a leak.....
    Last edited by IndianaVX : 07/24/2011 at 10:19 AM Reason: Forgot stop leak comment.....
    1999 silver 1346
    I have never used stop leak but looks like im going to try to replace the rad.
    Does anyone know how easy this is? is there any tricks i need to know?
    Jun 2007
    2001, Proton
    pressure test
    pretty easy to do or have done. Boiling out the radiator is also an option but replacement radiators on ebay have been inxpensive
    Carter Pewterschmidt
    1999 Astral Silver VehiCROSS #1214
    Zadam, you're jumping through all the same hoops that I did. I had the EXACT same problem. I replaced my radiator too and it didn't fix the problem. Did you ever check those head bolts?
    -Paul
    1999 silver 1346
    Quote Originally Posted by phines View Post
    mechanic told me if the head bolt was broken it would have failed the compression leak test i did, not sure now if it is true since he said it was definatly the thermostat
    video here
    http://www.youtube.com/watch?v=X05PDw5IE1U
    1999, Ebony Black, 1856
    I have a similar issue...mine seems to start to overheat when I turn on the air...I too have replaced the fan clutch, thermostat, flushed the system, O2 pump...I'm not loosing any fluid
    I've an appt with a really good shop here in town...I play soccer w the owner...we'll see what they come up with...only prob, it's going to about 10 days till I can get in...I'll post back then...
    Did you read this thread on aluminum radiators? If you do find that you need a radiator, maybe this would be a good investment? I dunno how much they cost vs. OEM/aftemarket though.
    http://www.vehicross.info/forums/sho...threadid=20866
    May 2011
    1999, black, VX, 0429
    Water pump.....
    A failed water pump will cause the engine to heat up at speed, where as if it is a radiator issue or fan issue etc. the engine will normally cool down going down the road and heat up at idle. Water pump symptoms are almost completely reverse other overheating problems. Just my two cents.
    "hey ya'll watch this!!"
    May 2011
    I just replaced my radiator last week because the top plastic tank seperated itself from the aluminum tank. I guess what I'm saying is these things seem to have a few issues with the cooling system from what I am reading.
    Quote Originally Posted by zadam123 View Post
    video here
    Yeah, my mechanic didn't believe it was the problem either. But after a trying everything else, we decided to replace the head gasket. That's when we found the problem.
    Not sure the compression test will show anything unless you do it after running the engine pretty hard and do the test at higher rpm's.
    1999 silver 1346
    when i did the test i did rev the engine to see if at high rpm it would fail but still passed the test. I am going to take the rad off this weekend and have it testted by a radiator mechanic
  1. Cracked Radiator
    Last Post: 04/03/2013, 04:20 AM
  2. 160,500 k and a New Radiator
    Last Post: 07/22/2010, 05:27 PM
  3. Driving problem fixed/TOD problem realized
    By mattlewis9333 in forum VX Troubleshooting...
    Last Post: 02/26/2010, 06:57 AM
  4. Radiator
    Last Post: 04/22/2008, 06:36 PM
  5. Aluminum Radiator
    By MachineVX in forum VX Modifications...
    Last Post: 06/22/2005, 05:56 PM
