So I got my Vx 2 weeks ago and I've begun to try to fix/upgrade all the issues
The 1st two I tackled are the window binding & cup holder problems.
I have a temporary & permanent solution for the window problem
Temporary: I used the mount from a gps unit with a suction cup. I stick it to the window and hold on to it to guide the window up & down. I can take it off easily if i wish, but i leave it on.
For a permanent solution, the problem appears to be that the metal bracket that goes up and down the tracks and attaches to the window is only gripping the tracks on the left side but not on the right.
On the right side it follows a the track but it doesnt grip it, so if it were pushed back it comes off the track easily.
If this can be fixed by adding a piece that grippes the track like it does on the left side, this issue can be permanently fixed.
I am working on this and if anyone can make this, plastic or metal, that would be great.
here are some pictures showing how it comes off the track.
right side of track
left side of track
So contact me if you can fix this or i'll update if i find a fix
Cup holder.
I purchased this very simple cup holder from auto zone.
I broke off the bottom piece and i used double sided tape on the back to secure it to the center console. It works great.
