Results 1 to 8 of 8
Thread: It seems like my rear seal is leaking
    Aug 2005
    1999, silver, 0887
    Post It seems like my rear seal is leaking
    It seems like my rear seal is leaking. I've changed the PCV, and the filler cap seal recently. I wonder if BAR's sealent or some other concoction would help. I'm using Mobil 1 High Mileage oil, 10W 30. Maybe that's too thin for 138K miles?
    Depends????
    Depends????
    Aug 2005
    1999, silver, 0887
    Thanks. I'm going to try a different PCV first.
    I'm just curious, how would the PCV affect a leaking rear seal? Maybe I'm not clear on what the rear seal is that you're referring to?
    Wrench
    Quote Originally Posted by blacksambo View Post
    I dunno that I'd go too much thicker on the viscosity. The closer tolerances on a modern quad cam lump require the lubricant to be able to move through those same tolerances to be effective.
    Are you gonna replace the crank too?
    Wrench
    Rear main crankshaft seal...would leak more with increased crank case pressure.
    Aug 2005
    1999, silver, 0887
    Thank you.
    I changed to synthetic after 65K. The maun seal leak seems to be intermitment. It got better after I changed to High Mileage oil that addresses main seal issues, but that was during colder weather. I'm going to replace the PCV, and then watch. If it persists, then maybe Bar's main seal sealent additive? I hate to pull the tranny for such a small leak, but it bothers me and synthetic oil is expensive to keep pouring into a leaky crank case. (Is there anything elae that can leak directly above the main seal area? Probably not. )
  1. Rear Differential leaking
    By AndyC in forum VX Troubleshooting...
    Last Post: 08/16/2014, 08:08 PM
  2. Outer rear axle seal tips?
    By Triathlete in forum General Tips...
    Last Post: 12/10/2012, 08:21 PM
  3. Main Rear Engine Seal Question
    By blacksambo in forum VX Troubleshooting...
    Last Post: 02/01/2010, 05:38 AM
  4. Rear Axle Pinion bearing & seal
    By Jolly Roger VX'er in forum VX Troubleshooting...
    Last Post: 04/22/2008, 03:31 PM
  5. Rear axle seal
    By Project Big 1 in forum VX Troubleshooting...
    Last Post: 01/21/2006, 07:20 AM
