Results 1 to 15 of 27
Thread: Time to get an easy out kit...Errrr.
    Sep 2010
    2000,Ebony,VEC,0013
    Angry Time to get an easy out kit...Errrr.
    I was replacing my EGR valve and those *&^%$# bolts just wanted to cross thread into the plenum and Gee well what do ya know one did I busted the bolt off in the intake. A ten minute project is now and hour plus and can't do till saturday. I haven't drank in 30 years. Sometimes I just wish I did!!!! Errrrr.
    When yer done. Bring it up to VA. I gots 2 busted off bolts for the rear cladding.
    Sep 2010
    2000,Ebony,VEC,0013
    but at least yours is running!!
    Yah, but my rear end flutters in the breeze.
    Jun 2007
    2001, Proton
    that beingthe case
    Put some pants on
    Carter Pewterschmidt
    Sep 2010
    2000,Ebony,VEC,0013
    Alright for those who want to chime in on my difficulties pleeez do. At the time my trans was redone the trans man asked me if I had misfiring: no. He said well it is and thought maybe I had a coil pack problem but I wanted it back so I took it home without him checking the problem out a week ago.
    I have had an over all loss of power that is esp bad when trying to excellerate from 35 or 40. depress the pedal and no response. hold it there and in 5 to 8 seconds the engine begins to kick in and excellerate then it will throw my back aggainst the seat and behave like nothings wrong. esp in the higher rpm.
    My opinion has been all along that it is a fuel air mixture - fuel delivery issue.
    I replaced the fuel filter. nothing
    I cleaned the MAF. nothing.
    I dumped seafoam into the tank. ..ran great 5 miles then prob back.
    Ipulled the codes: P0300 random misfiring and o2 sensor bank 1 sensor 1.
    I replaced the o2 sensor on both forward banks. nothing.
    I replaced the plugs. nothing.
    I have been thinking bad gas all along and am down to a quarter tank. I filled a new tank the night beforre the trans died. so index of suspicion up.
    What could the trans man have done if it is something his actions caused???
    I pulled the EGR valvelast night. I plugged the plenum inlet and laid the EGR valve on the top of the engine and turned the engine on with the harness connected to the EGR valve. The engine was pretty much up to temp. So I revved the engine and watched the EGR valve pinion . . It did not move at all- ever. Did not open. So with my backyards mechanics mind I figured just maybe that valve is not responding. So I got a new one and now here I am with a broken bolt and still misfiring engine.
    If this is still misfiring after I whip this EGR prob and get new gas then the only thing I can think of is to buy a coil pack and play musical chairs with it in the hopes that it will finally hit on a cylinder that had a bad coil pack. but wouldn't I have thrown a P0301 -0306 code? by now???
    Oh and I checked the fuel pressure with a tester on the rail. With the key on it pops up to 38. After starting it drop to a steady 31-34 psi.
    My idle is fine. when it does get going it is smooth. ???? any thoughts.???....maybe its the Throttle position sensor.... Gee I will buy one those next.
    Sep 2010
    2000,Ebony,VEC,0013
    I Want My Power Back
    I'm singing: HELP! I need somebody. Help not just anybody.........
    Sorry to jack your thread before you were ready.
    Is there any way to easily tell if your timing belt jumped a tooth. Kinda sounds like a timinig issue to me.
    Sep 2010
    2000,Ebony,VEC,0013
    All I can say is "OH cr***p" I didnot think of that. But there is some intermittent nature to the prob. Like after dumping seafoam in it ran great for several miles and thought this stuff just is the cats meow. Not.
    Sep 2010
    2000,Ebony,VEC,0013
    In the manual it talks of testing coils with an ohm testing meter. Anyone ever done this. ?????
    Jan 2008
    1999 Astral Silver 0481
    Exclamation
    Quote Originally Posted by Ebenezr View Post
    My brother-in-law axiom had the same but very same issues
    My mech did the following :
    Examined the entire engine and noticed there was a crack in one of the valve covers ( Hopefully this doesn't apply to you );After the valve cover was repaired compression testing was performed to make sure engine was completely seal off,EGR was cleaned out,( OMG how clogged that son of a B.... were )
    The mech proceeded to replaced one of the coils wiring because it was faulty and causing the misfire ( You may want to have ALL coils & wiring checked for proper operacion ) The truck won't move foward on low RPMS,but take off like a rocket on high RPMS ( Spark plugs were also replaced ) Don't try to cut corners and get the best ones out there.
    The mech also replaced fuel pump,after new one was installed he tested to make sure wiring was not faulty.
    Transmission was rebuilt because it was shifting roughly,no shifting or stall just like your VX.
    And finally radiatior was replaced and brand-new antifreeze to make sure car can be just cool during the summer.
    After all that was taken care off axiom is running like a champ
    Dakar was just the begining.
    Wrench
    A few random thoughts...
    If it were the timing belt, it wouldn't run right at any rpm.
    You don't need a new coil pack to play "musical chairs", though the random misfire code isn't pointing to a specific coil pack, which makes it hard to know which one to switch first. (to see if the misfire code moves with it after resetting the ecu)
    Any unmetered air getting into the system via leaks in any vacuum controlled system will wreak havoc & throw "codes-a-plenty"...
    As a last, or maybe first resort, try to find a VX Bro or Sis who is sympathetic to your problem, & switch ECU's, to see if that's the culprit...
    '01 Ebony #0939
    Fuel pressure regulator? Very common VX ailment it seems, and a faulty one would be causing the symptoms you've described.
    Sep 2010
    2000,Ebony,VEC,0013
    Quote Originally Posted by Y33TREKker View Post
    I did check the fuel pressure as mentioned above. It was 38 with key on and 32-34 with the engine on. I'm thinking now that may be low. Does anyone know what it should be. I can't seem to dig up this info.
    Right but would show up more to the Butt Dyno during acceleration rather than RPM related. Remember the timing lag on the old MOPAR engines???
  1. Easy Task for Most of You
    By nemo in forum VX Talk...
    Last Post: 10/29/2009, 09:05 AM
  2. Easy TOD off switch!!
    By kodiak in forum VX Modifications...
    Last Post: 06/04/2009, 10:02 PM
  3. Easy Huh!? Shock Install help...
    By xdfarrx in forum VX Modifications...
    Last Post: 07/25/2007, 03:01 PM
  4. Easy Horsepower
    Last Post: 06/24/2004, 01:34 PM
  5. Go easy on me I'm new!
    By tritonsmoon in forum VX Troubleshooting...
    Last Post: 02/18/2003, 03:04 PM
