Results 1 to 9 of 9
Thread: Power steering fluid leak!
    Apr 2006
    2k Ebony
    Power steering fluid is "gushing" out! I thought its the low pressure line so I repalced that. After that, I still see a lot of leak!
    Weird. I haven't noticed any leaks but the power steering fluid was very low on the VX last time I checked. I'll have to keep an eye out for leaks.
    On the other hand, the steering box was re-built after my accident last year (new sector shaft installed). The fluid loss could have been the system purging itself.
    May 2007
    1999 Black Rodeo
    Not sure if your pump is set up the same as mine since my rodeo has R&P steering but when I had a leak it was a bad o-ring on one of the hoses where it bolts to the pump.
    --Dave
    2001, Ebony Black, 1153
    There is a sensor on the bottom side of the pump that can vibrate loose. This has happened to me before. I have replaced my pump well over 4 times trying to find one that does not whine with my big tires + wheels :-( haha
    Can you tell if it is leaking from the pump, the reservoir or the hoses? When my Trooper's PS blew, it all came out at once and I lost power steering right then and there....
    Apr 2006
    2k Ebony
    It looks like it is coming from the fitting to the steering box. Does that have an O-ring? I thought it was a flared fitting.
    I'm not sure about the VX, but I am pretty sure it was the o-ring at the blew on the bottom of my steering box in the Trooper. I just replaced the whole steering box with a remaned one.
    Oct 2012
    2001 Vehicrss
    The fittings are flared (flange) going into the gearbox. This being the case there is only three ways it can leak. 1. The flare itself has cracked or chipped (and yes I have seen this many times on many different aircraft and vehicles). 2. The fitting has some how backed off. 3. The fitting was way over torqued and stretched the threads and now over time they have become useless.
    Aug 2007
    2001, Proton, Vx, 0000
    You are correct. There is indeed a copper washer there. Get a brand new one as replacement.
    I made a mistake of re-using original one after hose replacement job I did a while back. Needless to say I had to do that job twice!
    - Dion
  1. I noticed my power steering fluid leak...
    Last Post: 03/27/2015, 09:50 PM
  2. Leaking Power Steering Fluid
    Last Post: 11/10/2008, 06:50 AM
  3. Power Steering leak
    By Dino in forum VX Troubleshooting...
    Last Post: 10/25/2007, 04:43 PM
  4. Power Steering Fluid
    Last Post: 09/05/2006, 11:02 AM
  5. Brake Fluid vs. Power Steering Fluid
    By TEN36VX in forum VX Troubleshooting...
    Last Post: 07/01/2006, 04:12 PM
