Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: Is the vx a reliable daily driver?
    Sep 2011
    dont have one yet
    Hello all! I have three vx's for sale in my area and think they are really interesting vehicles. Assuming i fit in one (6'5") my only other concern is how is the reliability? From what I've read they seem like decent enough vehicles but I wanted word from the people who own them! So any input you have for me would be greatly appreciated! Thanks for your time and input!
    Jeff
    In a word..YES.
    Just be aware of the oil consumption issues some have...
    ...check oil every fill up, or until you are confident its not using.
    Feb 2010
    2001,Kaiser,1130
    Its as reliable as a 10 year old vehicle would be, expect to change items like plugs, shocks, do brakes, tires.. etc on those over 100,000 miles. Timing belt and waterpump get changes at 100,000 miles.
    The issues on all isuzus of this vintage are:
    -Possible oil consumption, leading to spun bearings and replacement of engine.
    Cause is not well known, but those that have been well-maintained may burn oil, but may not have the sudden evac problem. Mine is at 102K, but has no oil-burn. (knock on internet wood) I still check every gas fill-up.
    -ABS unit will fail eventually.
    The issues on the VX specifically:
    -The windows bind due to an engineering cock-up, where the window regulator's plastic bits and the window channel rubber has about a 30-40,000 mile life. After that they bind to the point where you can't move them up and down without help.
    Gas mileage is poor - at best 17mpg city - at best.
    If your not looking to do work on the car yourself AND don't have money for a mechanic - don't get a VX, get a 2003 honda civic or toyota corolla.
    Quote Originally Posted by atilla_the_fun View Post
    I couldn't agree more. If you're the type of person that likes having car just for transport then there are much better choices of vehicles. I've done a lot of upgrades & preventative maintenance to avoid any major mechanical issues (knocking on wood).
    Also, you will fit fine in a VX, i'm 6'6" and fit fairly comfortably. You can check out my VX and take it for a spin if you want, i'm just a ways down the road from Greeley.
    Sep 2011
    dont have one yet
    Thanks for the info! I have a full shop available to me so i can do quite a bit. Oh, and ignore the double post...not sure why that happened.
    Sep 2011
    dont have one yet
    Okay. So if it is burning oil, what is the recommendation?
    Sep 2011
    dont have one yet
    These are the two vehicles I'm considering. http://denver.craigslist.org/ctd/2579246552.html
    http://denver.craigslist.org/ctd/2537202154.html
    I like the looks of the first one better but am wary about anything that has been modified at all. Do these readily accept bigger wheels and tires or is that going to cause problems? I also like that it is the last year of it. The first has the lowest miles but is the oldest. Any other thoughts for me? I'm planning on looking at both of them tomorrow.
    Aug 2010
    01 Foxfire Red Mica VX 0441
    Quote Originally Posted by adsero View Post
    From what i've read from other people on here, check the oil level at fuel ups. Also, seems most burn oil on longer trips. You can always check your temp guage too. I believe the 2001's were a little less likely to have the issue.
    2001 VX
    Mods
    2008 HUMMER H3
    OK, here's a mega post with a TON of info....better plan about 3-4 hrs of reading. Most of us here have read and studied much info available on this forum. The group is very knowledgeable about these trucks, and very happy to share the info and help noobes. But it will help you greatly, if you do some of your homework and read up on some of it too.
    I've pulled together several groups of threads on specific topics, so I can pull them up in a flash and post them here for new folks like yourself.
    There's a few threads or posts that are repeated in my lists below, but not that much, there's just a lot of information on this forum, and it's all worth reading. Of course it's by no means all inclusive, but it's a good start.
    Notice I've put Oil Consumption in RED letters...it's probably the most important to read. Also, it's not usually BURNING oil (as you mentioned in post #6), and it's not leaking or dripping.... it's consuming oil, and the threads below explain that.
    Also, here's a link to a post that discusses several general VX issues and things to consider before buying one:
    http://vehicross.info/forums/showpos...52&postcount=4
    DETAILED QUESTIONNAIRE:
    Also, we put together a detailed questionnaire VERY specific to the VX.
    It's kind of like a ROAPMAP to specific area you should learn about and check out on any VX you consider buying.
    (I also have a much longer, more comprehensive questionnaire covering many additional areas. Let me know if you're interested in seeing that 100+ questionnaire also. It got so long, it kind of became a joke , cuz it's just overkill, .....but still has some dang good questionnaire and info to check on a VX)
    http://vehicross.info/forums/showpos...36&postcount=3
    OIL CONSUMPTION:
    http://vehicross.info/forums/showpos...16&postcount=7
    http://www.vehicross.info/forums/showthread.php?t=9010
    Several theories on Isuzu design defect in rings that causes oil consumption:
    http://www.vehicross.info/forums/sho...rand+pcv+valve
    http://www.vehicross.info/forums/sho...6&postcount=20
    ENGINE FAULIRE POLL:
    http://vehicross.info/forums/showthr...E+FAILURE+POLL
    CHECKING TRANNY FLUID LEVEL:
    http://www.vehicross.info/forums/sho...0&postcount=18
    http://www.vehicross.info/forums/sho...nsmission+mode
    OFFICIAL ISUZU RECOM FOR FREQ OF CHANGING TRANNY FLUID:
    ROUGH AND DUSTY ROADS-> EVERY 20,000 MILES
    http://www.vehicross.info/forums/sho...1&postcount=19
    WINDOW FIX THREADS:
    Window problems are probably one of the most common issues on the VX.
    They are notorious for binding, sticking, jumping the track, tilting, burning up the motors due to the severe binding....you get the idea..
    Here's a bunch of threads that have good info on the issue and how to repair. As time went on, most found that buying the SBC metal brackets for $65 was the best fix. It's what I did.
    JOSHI's bungee fix thread:
    http://vehicross.info/forums/showthr...hlight=zip+tie
    The bungee cord window fix: (Joshi and SlowPro48 have done it)
    http://www.vehicross.info/forums/sho...63&postcount=9
    http://www.vehicross.info/forums/sho...window+binding
    http://www.vehicross.info/forums/sho...ow+binding+fix
    http://www.vehicross.info/forums/sho...n+track+window
    http://www.vehicross.info/forums/sho...58&postcount=4
    http://www.vehicross.info/forums/sho...threadid=10278
    http://www.vehicross.info/forums/sho...7&postcount=26
    http://www.vehicross.info/forums/sho...0&postcount=27
    http://www.vehicross.info/forums/sho...7&postcount=31
    http://www.vehicross.info/forums/sho...8&postcount=38
    http://www.vehicross.info/forums/sho...+binding+track
    http://www.vehicross.info/forums/sho...t=window+track
    http://www.antiquecaterpillar.org/vx...cal/Window.asp
    http://www.antiquecaterpillar.org/vx...indow_Bert.asp
    I recall there was one owner (Bulldoggie, and then tysamigo) that neither of the above helped. He tried putting some metal washers in a stack, maybe 1/2" or so, to act as spacers and push the bottom of the glass outward, and of course that made the upper part of the glass tilt inward more. I believe that solved the tilting and jumping the track issue. I recall he just kept adding washers (thickness) until the angle was optimized.
    Also, many have widened the metal rail/track the leading edge of the glass runs in, to reduce friction/ pressure on the glass. I used pliers and opened up the C-shape metal track until it was wider at the edges, particularly near the top as that's where I could see it was binding.
    INFO ON LIFTING THE VX, AND BIGGER TIRES/RIMS:
    http://www.vehicross.info/forums/sho...&highlight=ome
    CV JOINTS & AXLES, ISSUES, PARTS COMPATIBILITY WITH OTHER ISUZUs:
    http://vehicross.info/forums/showpos...8&postcount=18
    HEADLIGHT RESTORATION THREADS:
    http://www.vehicross.info/forums/sho...ht+restoration
    OEM ISUZU PARTS GUY- CONTACT INFO:
    Merlin
    St. Charles Isuzu
    MISSOURI
    (800) 727-8066
    Mention the forum to get discount & free shipping.
    Enjoy! Hope you catch the addiction too!
    More questions, just holler.....
    Mar 2006
    2001 FOXFIRE 0579
    Yes, what they all said, and I usEd to be 6'9", but I'm getting old, so I'm about 6'8" and I'm fine driving the truck, and I drive mine every day easily 6-700 miles a week. I do most all of the work on the truck myself. You will find, when you look under the hood that u can still acess the engine without alot of trouble!
    Good luck, and look forward to the possibility of welcoming you to the family!
    Aug 2008
    I'd say the VX makes a great "secondary" vehicle for specific pleasure outings and/or for inclimate weather conditions, but not as a daily driver. For a daily driver, get yourself a roomy gas mizer vehicle (since you're tall) that has a very high MPG rating near the 40 MPG mark.
    Sep 2011
    dont have one yet
    Did i mention i like yall already? Thanks for the info.
    Feb 2010
    2001,Kaiser,1130
    better yet, buy a VX with no engine and do a tdi swap.
    Ive been driving mine daily for 5 years with no major issues.. Replaced 1 alternator and 1 ABS module, but other than that nothing but routine maintenance. You need to be diligent with checking your oil. The vx is a known oil burner and many many people have had their engines seize ater burning too much oil without being replenished
    I have looked at both of these and I would not even consider the second one (99 Black in Castle Rock where I live). I has lots of rust and some other issues as well. This same place has a 2001 Kaiser that looks much better in the ad but I have not seen that one in person.
    The Kaiser at Sharpest Rides was in good shape. It has the back interior plastic cut out under the cubby for the lug wrench. Not sure why anyone would cut that out, but it is just a big hole that goes all the way to the body panel. The windows bind on the VX passenger side. It sounds good and has a new windshield. The hood insert and hood are cut out for the scoop so you have to be okay with that. I would say it's worth about $7K.
    Good luck with your search.
  1. Suggestions for a Daily Driver
    By FlyingV77 in forum Chit-Chat ...
    Last Post: 02/19/2014, 03:05 PM
  2. My new daily driver
    By deermagnet in forum Chit-Chat ...
    Last Post: 11/07/2012, 07:31 AM
  3. New baby and new daily driver
    By samneil2000 in forum Chit-Chat ...
    Last Post: 04/07/2011, 01:57 PM
  4. My new Daily Driver
    By VehiGAZ in forum VX Talk...
    Last Post: 06/18/2008, 08:08 AM
  5. RELIABLE After Market Warranty?
    By KristyRemo in forum VX Talk...
    Last Post: 06/08/2004, 02:20 PM
