Results 1 to 8 of 8
Thread: Steering Gear box Hose
    Jun 2003
    1999 Victory Ironman 1703
    Does anyone have any suggestions where to get the hose that goes from the top of the steering gear box to the reservoir (not pump)?
    Or to get one made?
    Mine is leaking at the fitting at the gear box.
    Make sense?
    Jon
    Edit: I was having left resistance in the wheel and tonight found the reservoir near empty with fluid on the gearbox, with fluid pooled in the metal hose fitting.
    St Charles Isuzu
    Jun 2003
    http://catalogs.marketparts.ru/isuzu...fHxuaT09MDE%3D
    Part 197 (PS return hose) in the diagram. Wonder if this is letting air into the system and causing the wheel resistance when turning left.
    Sep 2010
    2000,Ebony,VEC,0013
    Mine had leftward turning resistance. I replaced the steering gear. Steering gears are cheap used. Go to the used part finders and search for a same year Trooper steering gear and you will find tons of them.
    Jun 2003
    Quote Originally Posted by Ebenezr View Post
    Did you replace it yourself or a shop? If a shop do you mind me asking what it cost in labor?
    Thanks!
    Found another link with the Vehicross as root:
    http://www.catcar.info/isuzu/?st=50&...fHxuaT09MDE%3D
    '99 Astral #1372
    Steering gearbox return hose. P/N 8-97178427-1
    It's like $25 bucks from Isuzuparts.com or call st. Charles. You can replace it, just be careful putting it back onto the plastic reservoir or you'll snap the bung off and have to replace the reservoir. Good news is the reservoirs are now back in stock
    Sep 2010
    2000,Ebony,VEC,0013
    Quote Originally Posted by Jonnie View Post
    Thanks!
    Replaced myself. level of difficulty was moderate. If I remember pulling the pittman arm off wasn't easy ..you need a good puller. You might get lucky and receive a steering gear with one. Remember it goes on keyed. I had a mechanic do it first and he rammed it on. I had to do his work over cause I lost my turning radius to the right...he didn't center the arm back on correctly.
    Jun 2003
    Thanks, Ebenezr.
    Its been pouring in Tampa and my drive for my bungalow is 2 cement runners so its not ideal place the more I think about it. Seems not too bad if you have a lift. I'm going to have a local shop do the work on Monday, hopefully not too $.
    I picked up a Trooper gear box with 20K miles on it today- looks almost new. and it has the pitman on it.
    So I'm grounded for a little while; so much for catching up on work at the office this weekend.
  1. P/S Hose routing through the gear box
    By sindarin in forum VX Troubleshooting...
    Last Post: 07/17/2014, 04:51 PM
  2. Power Steering Hose replacement question
    By mrlegoman in forum VX Troubleshooting...
    Last Post: 05/03/2013, 06:26 AM
  3. High Pressure Power Steering Hose Installation
    By Lizardmen3477 in forum VX Troubleshooting...
    Last Post: 01/20/2012, 05:48 PM
  4. Power Steering Hose Replacement - Need Advice
    By bentcipher in forum VX Troubleshooting...
    Last Post: 08/19/2007, 09:28 PM
  5. power steering hose
    By monkeyhaas in forum VX Talk...
    Last Post: 12/08/2004, 07:49 PM
