Results 1 to 7 of 7
Thread: Newbie with VX question
    Looking at a VX and drove it. It had a little odor of
    anti-freeze inside the car, very slight but there. I am enough
    of a car guy to know the smell. I do not know a lot about
    the VX yet and do not own one (trying to) but is there a
    symtom of this. I am thinking maybe a leaky heater hose,
    one or two drops can to it. Any thoughts out there.
    Feb 2010
    2001,Kaiser,1130
    heater core failure?
    My VX smells like strawberry, so the antifreeze smell that you describe is definitely not normal for these cars. =)
    Jun 2007
    2001, Proton
    Ditto
    Quote Originally Posted by atilla_the_fun View Post
    Have it checked before buying
    Carter Pewterschmidt
    A slight smell could be caused by a spill under the hood or some boli over. That will go away. There could be a leak either under the hood you should be able to smell that outside as well. If it's only inside check the heater to make sure it's not leaking.
    Check the passenger floor for wetness. Lift the mat and feel if it is damp, if not, rub your hand on the floor and see if you can smell coolant on your hand. If it is wet, heater core for sure. I would look under the hood and under the engine on the ground for coolant leaks also. Check the overflow reservoir and see if there is coolant in it and note the color.
    How many miles on the VX in question? What year? Any service records?
    I would guess heater core.
    That is the best screen name ever, BTW.
    THIS WE'LL DEFEND
    Aug 2011
    1999 Silver
    My son's VX smells like AXE cologne. Check the heater core as previous post stated. Neat vehicle. If you buy it keep this forum on your favorites!
  1. Newbie needs help,pls.
    By lukeno1 in forum VX Talk...
    Last Post: 07/13/2008, 04:34 PM
  2. Newbie question...again AC light
    Last Post: 11/25/2005, 05:51 PM
  3. Newbie Questions??????
    By mndwgz in forum VX Talk...
    Last Post: 08/22/2005, 01:21 PM
  4. Hey, newbie here, got a question on gearing....
    By CIATexan in forum VX Modifications...
    Last Post: 04/03/2005, 01:26 AM
  5. newbie questions~
    By GOVEHIX in forum VX Troubleshooting...
    Last Post: 11/22/2004, 07:52 PM
