Best Shocks
Originally Posted by
mantis465
if i could find the stock shocks for an affordable price i would go that route however that does not seam likely that is why i am asking which would be best replacement for my needs
If you have a budget you should list it as the may limit your choices. Also since you do not plan to 4 wheel yopu may not need the best just the best for your use. Also what kind of ride do you want? Need info to make suggestions
Carter Pewterschmidt
