Results 1 to 4 of 4
Thread: driver side door panel
    Oct 2009
    2001 Mica Green VCS 0403
    Exterior door handle quit working on wifes VX. I am going to attempt to remove the interior door panel this weekend. Any tips on removal of panel or possible problem with handle would be welcome.
    Thanks,
    Soggy
    Usually its the plastic clip that attaches that breaks. Zip ties can be used as a temporary fix.
    When you remove the screw for the tweeter pod, you still have to slide the pod towards the window. Dont just pull
    Once you remove the window switch handle (pry up from front and side toward door hinge) there are two screws behind it holding the door in place. The last screw is on the door opening handle.
    There are push fastners holding the edges of the door on and 1 on either side of the opening hale. Be careful with those because if you forget about them you crack the carbon fiber piece.
    You may need a blow dryer or heat gun to get some of the push fastners loose without breaking them. Depends how cold it is. Same with the plastic vapor barrier behind the door. to remove that definitely heat up the adhesive to avoid tearing.
    Its very easy to get the panel off but like etlsport said, it takes some care to get the clips popped without breaking them. I usually start at the outer bottom corner with a long flat head & then pop all the bottoms clips first before the sides. After getting all the clips pulled, the panel slides upward out of the window channel.
    Rowhard did a great write up "How-To" on this:
    http://www.vehicross.info/modules.ph...warticle&id=22
  1. Replies: 19
    Last Post: 10/22/2010, 05:47 PM
  2. door panel
    By harvey phillips in forum VX Troubleshooting...
    Last Post: 10/03/2008, 11:12 PM
  3. Need interior (driver side) door handle
    By tbrewton in forum VX Modifications...
    Last Post: 08/09/2006, 09:56 AM
  4. Driver Side Door Pull Part #
    By chumone in forum VX Talk...
    Last Post: 06/02/2005, 11:23 AM
  5. Scraped bumper and side panel
    By BuffArchitect in forum VX Troubleshooting...
    Last Post: 10/29/2003, 06:54 AM
