Results 1 to 2 of 2
Thread: trans slipping
    Nov 2007
    1999 Astral Silver
    trans slipping
    this is a weird one, but seriously there are many times
    Ill take a right turn, maybe a little faster then normal..
    and right after I do it, my trans will slip from 3rd to OD.
    I usually have coast for a bit, using no gas, and after a
    few seconds, the trans will catch again and off I go.
    After I went thru the steps of topping off the fluid on my
    trans a few weeks ago, its done it less, but stilll has
    happened a few times.
    Not to mention, Ive had some overflow of trans fluid on
    my driveway several times in the last few weeks. ugh.
    Check out our VX accessories @
    www.planetsvx.com
    click on the Vehicross button on the left side
    of the page
    Apr 2011
    1999 Astral 0074, 2001 Proton, 1999 Ebony, 1999 Astral 0163
    As far as the leak, you may have to replace the front seals. Have your tranny serviced, have the filter replaced. It may have lost a bolt, which is why when you turn right, it does that. It may be loose. Be sure they CHANGE your filter....a lot of places will "service" your tranny but not change the filter. This advice is from my husband, who builds transmissions for a living.
  1. Transmission Slipping
    By DeepSilentComplete in forum VX Troubleshooting...
    Last Post: 10/29/2012, 02:45 PM
  2. 1870 trans slipping code. Crap
    By MustangO4 in forum VX Troubleshooting...
    Last Post: 06/26/2012, 09:19 PM
  3. Transmission slipping
    By TRUSFJ40 in forum VX Troubleshooting...
    Last Post: 09/11/2011, 09:34 AM
  4. Trans slipping
    By 01VX in forum VX Troubleshooting...
    Last Post: 02/24/2004, 10:34 PM
  5. 1st gear slipping
    By Pete in forum VX Troubleshooting...
    Last Post: 12/08/2003, 05:14 PM
