Results 1 to 4 of 4
Thread: Dome Light doesn't turn on with driver door
    Mar 2011
    99, Orange, VX, 0398
    So since I bought my vx this spring, the dome light hasn't worked with the drivers door. It goes on and turns off as it should with the passenger door, but does not react at all to the drivers door. It also works fine when you push it on and off. I replaced the switch that the door hits on the door frame and checked its ground but it made no difference. Anyone have any ideas or suggestions before I start chasing wires with a voltmeter?
    Sorry I can't help you but please post your results since mine hasn't worked in years.
    Hi,
    Since I have had my interior apart, I added a rear gate pin switch. The driver's side door switch sends a ground signal to the dome light and alarm circuit when the door is open. If your switch is good, and you have a good ground, then your signal is not reaching the light/alarm circuit. If you cannot trace the wire all the way through its harness, which I doubt, then you could run a jumper wire from the driver's side switch to the passenger side switch and let the ground signal get there through it. I think there is only one wire going into each switch. If there are two, one is ground and one is ground only with door open. Just find the switched ground, and connect with 18 ga. wire from one side to the other, under the carpet.
    Good luck,
    Dave
    Mar 2011
    Great Idea. Thanks! yeah the problem is definitely before it reaches the switch, because I should be able to operate the light just by touching the positive to the frame and I can't.
    Tom, does one of your doors turn on the light? or do neither of them work?
  1. Dome light tap on/off?
    By JULIAN911 in forum VX Troubleshooting...
    Last Post: 04/06/2015, 06:37 AM
  2. Help with wiring light acces. to dome light
    Last Post: 11/24/2013, 09:49 PM
  3. Driver's door weatherstrip
    Last Post: 09/01/2010, 12:29 PM
  4. Dome Light out
    By GirlLikeThat80 in forum VX Troubleshooting...
    Last Post: 10/27/2003, 11:13 AM
  5. Dome Light
    By Vasha13 in forum VX Modifications...
    Last Post: 06/07/2003, 09:28 AM
