Results 1 to 9 of 9
Thread: Drive Shaft Rebuilding
    Aug 2005
    1999, silver, 0887
    Post Drive Shaft Rebuilding
    Can you just repalce a driveshaft U joint or are you better off rebuilding the existing U joint to avoid having to rebalance the whole shaft? Thx
    You should be okay just replacing the UJoint. Just pay attention to the orientation of the flanges...mark them and put them in the same position.
    Aug 2005
    1999, silver, 0887
    Great. Thanks.
    I wouldn't go the rebuild route yet. LittleBeast is looking into a shop that will modify our driveshaft to replace one of the U Joints with a CV. If the price ends up being right, that would be sweet.
    Aug 2005
    1999, silver, 0887
    Interesting. I guess you'd have to give up driving for a while, though?
    There should be one 'float' available already (mine). His should be available when you are ready to purchase & yours available for the next. We could check with a few other members that have parts trucks to see if they could provide an additional float.
    Aug 2005
    1999, silver, 0887
    Post
    Sounds good. Do you know how much the modified shaft will cost and about how much does it cost to ship a shaft? I'm at 12866. Many thanks for the follow up.
    2001, Ebony Black, 1153
    Not sure but if it is possible given our stock connections this guy will figure out a way to get it done. To correct the pinion angle you need to increase the length of the lower links and the drivetrain guy said I should consider lengthening the driveshaft as well, so that will be one other thing to consider when he is looking into a possible upgrade for our factory driveshafts. The only reason to do this would be to beef up the driveshaft or to correct the vibration after lifting. With the CV/Ujoint driveshaft you will need the pinion angle to be zero in regards to the driveshaft.
    Aug 2005
    1999, silver, 0887
    Thanks. Not what I'm after. I'm running stock, no lift, just everyday driving.
  1. Front drive shaft
    Last Post: 02/17/2017, 06:02 PM
  2. front drive shaft
    Last Post: 02/01/2015, 11:41 AM
  3. ABS and drive shaft U joints
    By kitman3 in forum VX Troubleshooting...
    Last Post: 10/23/2013, 10:03 PM
  4. Front drive shaft in 2WD.
    By Dumke in forum VX Talk...
    Last Post: 05/02/2013, 05:16 PM
  5. Drive shaft problem
    By AU92 in forum VX Troubleshooting...
    Last Post: 10/12/2006, 05:48 PM
