Results 1 to 15 of 20
Thread: Rear door handle
    Dec 2011
    97 Astral Silver JDM R001
    Rear door handle
    My Australia license plate is too wide, i had to bend it to fit where it's supposed to, so i can't access the rear door handle anymore, i use the key to pull it open, but i'm afraid of breaking it, so: I thought about removing the oem lock and replacinf with a hot rod style handle, with the key on it, this way i can lock and unlock and open it easily just turning it not having to keep it locked all the time. I appreciate the community's input, this is just an idea for the future, but i decided to share with you guys. Will.
    maybe like that:
    http://www.ebay.com/itm/1946-1947-Ol...sories&vxp=mtr
    or like that:
    http://www.ebay.com/itm/1940s-NOS-tr...sories&vxp=mtr
    Aug 2008
    Errrr........No; I can sympathize with your delima, but that T-Handle method would look like total crap on the back door and take away from the beautiful clean lines of the VX. I'd just live with it and open the rear door slightly ajar with the factory key. Then grab the outside right edge of the door sill with my finger tips to open the rear door the rest of the way without putting continued stress on the door key.
    If not, then I'd figure out some way to mount a lateral skinny grab handle using only the top factory license plate bolt holes, so the lateral grab handle would be centered directly above the rear license plate. Perhaps some type of skinney chrome bathroom cabinet handle from a hardware store could be retrofited to bolt-up using the top license plate bolt holes as mounting points. This method would look a lot more clean and centered on the VX and not look shoddy like the lame T-Handle idea.
    Just my 2-cents.
    Dec 2011
    Just my 2-cents.
    That's what i'm talking about! opinions are welcome, i still think it's handy because i could open and close the door without having to lock/unlock all the time, but yes, it would interfere on the clean lines of the VX. Let's see what other members have to say. Thank you Riff Raff!
    Install a receiver hitch - buy a SuperBumper - make a bracket to attach the license plate to the SuperBumper - mount full size spare to rear door to hide the OEM license plate recess (spare gives you sump'n to grab when opening/closing the door).
    EEEEEEZZZYY!!!
    Dec 2011
    EEEEEEZZZYY!!!
    Looks awesome, i would do it if i lived in USA, impossible to get these parts around here, or someone that would help me to adapt, everything here is "illegal" a no one likes to get involved.
    Is it illegal to have a copy of your license plate made to fit the OEM recess (pretty sure that's kinda what they do in England - but may be a different case since the plates stay with the vehicle forever)?
    I would suggest installing a door popper and an electric release. Lots of good information on that here. Even if you don't do the electric release the door popper will push the door open when you turn the key...
    Jun 2010
    99, Silver, 1784
    ...or, just keep on keeping on.
    11 years and I've never used the "handle" at all. To the point that, last summer, I noticed it and did a double-take having forgotten there was even a handle to begin with. I just turn the key and pull - gently, of course - and then use the door's edge to finish the job.
    11 years.
    -V
    PS: I'm installing a popper anyway. LOL
    -VI VX VNIVERSVM VIVVS VICI-
    Feb 2010
    2001,Kaiser,1130
    Suction cup.
    Oct 2004
    99 Victory White Ironman 0685
    X2
    Chi Dog...Dog is my Co-pilot
    Onward thru the fog
    11 years.
    -V
    X2
    Took me about a year to see we had a handle on the back door... so yeah, pulling the key works fine.
    Braas, all the mentioned options are good (except your handle idea ). You can also mount a big spare tire on the back door, thats what I use for a handle .
    Nov 2007
    1997 SILVER
    Hi Will, not sure how much too big your rego plate is, but I cut about 15mm off each end of my plate to make it fit inside there perfect.
    I used a dremel to make the cuts, and if you didn't know it was cut, you wouldn't see it.
    I didn't cut into any of the numbers, so still legal.
    PK
    I've got a half key on my keyring that only works on the back door...
    Pulling on your key works for a while, but...
    Aug 2008
    PK
    Winner, winner, chicken dinner!!! This is probably the very best solution of all. Thanx, PK!!!
    Dec 2011
    PK
    That's why i always come to this site, to "consult the oracle" hehehe! It's better this way, i'll try that. i found out that there's some room for fingers where the license plate lights are, so no big deal. Thank you
  1. Door handle not working
    By Anita in forum VX Troubleshooting...
    Last Post: 01/22/2016, 09:01 AM
  2. rear door grab handle
    By jarvis in forum Chit-Chat ...
    Last Post: 07/17/2014, 06:32 AM
  3. Help w/ replacing Door Handle Pin
    Last Post: 05/17/2013, 09:37 AM
  4. Door handle????????
    By BigJoe in forum VX Troubleshooting...
    Last Post: 12/08/2007, 04:48 PM
  5. Door handle HELP
    By Cyrk in forum VX Troubleshooting...
    Last Post: 10/30/2003, 09:54 AM
