edit
edit
Thanks Mark.
I changed my plugs at 75K and it was a breeze like you said.
I used a section of vacuum hose to slip over the small plug end, lower it into the hole and turn it until tight enough for the hose to twist instead of the plug. Pull the hose off, torque the plug and and you're done!
