Results 1 to 15 of 19
Thread: K&N Apollo Cold Air Intake installed...
    Thumbs up K&N Apollo Cold Air Intake installed...
    OK folks, here's the pics and info I promised...
    The K&N Apollo "universal" intake kit is NOT a universal kit, and does not come with the needed accessories to mount the kit. That said... I highly recommend doing this mod if you would like a little extra performance. The kit is normally close to (or over) $200, but I found the it on Ebay for just under $90. Add the bracket (part #856004) for $21, and the 70mm - 80mm silicone adaptor (part #856001) for $19. Install it yourself, of have your trusted mechanic do it for you, and let the grins begin!
    As you can see, it lines up nicely with the air duct from fender and I opted to not use the flex tube that came with the kit.
    The performance gain was noticeable, and it sounds wicked! I have the PV1 cat-back exhaust system, and now my VX has an intake to complement the exhaust!
    The bracket needed to be tweaked a bit, but it worked. Why parts you need are not included in the kit just does not make sense... just charge an extra $50, and include EVERYTHING.
    My VehiCROSS
    Amazon has a few of them as well. Also gives you a package deal with everything you listed in the "frequently bought together"
    http://www.amazon.com/K-N-85-6001-Ho...=pd_sim_auto_5
    That looks familiar.
    I agree with everything posted above. I was also surprised the kit wasn't complete since it's listed as "universal." The air flow seems adequate and it makes a nice sound pulling air. Also, the intake body is water tight & hooks up to a snorkel nicely.
    2000 IronMan #11
    Water tight?
    Water tight?
    (when connected to a snorkel or breather tube)
    2001, Ebony Black, 1153
    Quote Originally Posted by nocturnalVX View Post
    http://www.amazon.com/57A-6044-57i-S...sbs_03_02_t_lh
    http://www.knfilters.com/search/prod...?prod=57a-6044
    Is this everything in one kit?
    Oct 2009
    99 Astral Silver
    It would certainly appear to be. However, the bracket appears to be different and it is bit more expensive than the amazon bundle linked above. However, it does come with a bit more stuff.
    I topped off the VX's gas yesterday, and again today just to see if there was any improvement in M.P.G. since putting the intake on. The numbers were crunched by Cece & myself just to make sure there was not any error...
    I went from getting an average of around 13mpg to a whopping 23mpg !!! Granted, I only used about a gallon of gas. However, I figure that (as more gas is used, and the VX gets lighter) these results will only get better...
    My previous best was 19mpg on the highway when the VX was bone stock. I should have done this AGES ago!
    Jun 2010
    99, Silver, 1784
    The percentage volatility in such a small measurement renders this observation completely and utterly futile.
    Think of it, if you didn't empty the hose the same way, that could be almost half of your "about a gallon" pumped.
    But hey, at least you didn't get too optimistic!
    -V
    -VI VX VNIVERSVM VIVVS VICI-
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    I agree. A one gallon observation is not significant or reliable.
    It takes at least a whole tank and really two is better.
    Don't forget to reset the ECM (disconnect the battery) and drive a few miles before you start the process!!!!!!!!!!!!!!!!!!!!!!!!!
    Aug 2011
    1999 Astral VX 0210
    While you're doing scientific research with this method, can you give us a speedo accuracy check from one revolution of your wheels?
    Personally, I was thinking of installing an instantaneous mileage readout just under the fuel gauge on the dash.
    I figure a sticker that says "CRAP" ought to be sufficient.
    May 2009
    What VX? Rodeo Crew Cab, Jackaroo chassis, Supercharged 3.5, Navara tub (!!)
    Qwners handbook entry:
    "This vehicle is fitted with an Isuzu 3.5 litre V6. If you are more concerned about fuel consumption than the Isuzu awesomeness we suggest you purchase a Toyota Prius"
    I moved from 1970 Torino Cobra 429, to a 1982 Mustang GT 5.0, and finally the VehiCross. I think the gas mileage is GREAT!!
    It's all relative. I would never try to compare it to my CBR600!
    Gregg
    2001 Proton Yellow #1379
    May 2012
    2001 Iron Man,Vehicross,0814
    How about a little more feedback about the mileage improvement now that you have over a year and a half usage since the installation. My neighbor installed a cold air intake and Magnaflow exhaust system on his Chevy truck. Big performance improvement and gas mileage too he said. Seems like when performance goes up, mileage goes down. But what do I know? Thats why I'm asking.
    Mar 2012
    sold
    Quote Originally Posted by Maddawg View Post
    you are correct - its simple physics of an internal combustion engine - the more air you can get in and out of the system (i.e. an intake /exhaust) the more fuel you can and will burn - no doubt about it
    also, if you have an intake without the proper exhaust to compliment it or vice verse they dont do much if any good except maybe change the sound it makes
  1. Cold Air Intake questions
    By Mile High VX in forum VX Modifications...
    Last Post: 09/13/2015, 07:13 PM
  2. Supercharger Cold Air Intake (CAI)
    Last Post: 11/24/2007, 06:52 PM
  3. Cold air intake
    Last Post: 07/22/2004, 05:31 PM
  4. Final word intake/cold box?
    By drdavidr4u in forum VX Modifications...
    Last Post: 10/26/2003, 06:51 AM
  5. cold air intake
    Last Post: 09/04/2003, 08:34 AM
