It depends on how tall it's gone. If it's just a couple of inches I'd say there is no prob. OME rear and T bar crank is perfectly fine. With bigger tires and lil lift you get speedo off, and a little stiffer ride, maybe some MPG's will go away as well. The key word in this argument is "moderate." Don't go huge unless you want to do some real work. 2-3" no CV problems, steering problems, alignment should be done after lift, not hard to put back to stock, if the old owner did it it's probably just t bar crank and either spacers or new springs very easy to reverse.
