Results 1 to 8 of 8
Thread: Cruddy water out the tailpipe?
    Ok, what can be the explaination of somewhat dirty water coming out of the tailpipe?
    Noticed my VX "leaking out of its bum hole" over the last few days, and it is something I never noticed before. What are the possibilities?
    1999, Ebony Black, 1856
    rusty condensation?
    The particles in the water weren't rusty "looking"... more like dark gray/black smudges floating in the water.
    Feed your VX more fiber!!!
    99' Astral Silver
    I'd contribute this to temp changes in your area. Has it been getting cooler in the morning or when you happen to notice this?
    If not , it could be related to your hesitation problem.
    Could also indicate a spark plug issue.
    Live Free or DIE!
    Actually, it has been getting a bit cooler in the mornings... this morning was 48 degrees when leaving for work. It's been raining a bit as well.
    Do you mean, like a bad seal around a spark plug?
    99' Astral Silver
    I guess with the plug comment I was referring to a bad gap or issue with the plugs performace itself. With water coming out though, I would say it's cuz the cooler weather.
    Spark plug issues will tell thier tale on your exhaust pipe but this will usually result in discoloration of the tip. Like black or white etc.
    I think your safe and would contribute this to the cooler weather
    Water and steam are perfectly normal. Water is a by-product of the combustion process, and when it comes out of the engine, it's hot, so it comes out as steam and if the tailpipe is cool, some of the steam condenses on its way out and dribbles out as liquid water.
    Make sense?
    Yeah, totally. Actually, I could be just being more cautious of what's going on around the VX right now, after changing much of the fluids and all... making sure everything got lubed correctly, and nothing is clanking around in there.
    The spark plug gap situation is something I may look into regarding my acceleration delay problem, though.
  1. Exhaust tailpipe- New type
    By Dmitrikr in forum Chit-Chat ...
    Last Post: 03/31/2011, 01:58 AM
  2. Water Depth
    By VCross007 in forum VX Talk...
    Last Post: 06/12/2008, 12:38 PM
  3. White smoke from tailpipe
    By Otto in forum VX Troubleshooting...
    Last Post: 07/02/2007, 09:03 AM
  4. Water on the floor
    By TechnoPope in forum VX Troubleshooting...
    Last Post: 06/27/2007, 01:35 PM
  5. tailpipe residue
    By Heraclid in forum VX Talk...
    Last Post: 06/02/2003, 07:04 PM
