Results 1 to 9 of 9
Thread: will a 3.2 work
    Apr 2012
    1999 silver 1685
    will a 3.2 work
    I just bought my first vx with a bad motor. I have a 99 rodeo with a 3.2 and I wonder if the 3.2 will work in the 99 vx.
    Mar 2012
    sold
    i have also wondered about this - the 3.2l engines seem to be cheaper and more abundant - and im pretty sure the japanese versions had the 3.2l but i could be wrong
    Wrench
    I believe you would need to figure out a way to move the ECU, along with the 3.2, into it's new VX home.
    May 2009
    1999 Ebony Black/Red
    I swapped 3.2 instead the seized original one. Identical fit. The only difference is the cylinder bore
    Nov 2007
    1997 SILVER
    Quote Originally Posted by ZubrAZ View Post
    Actually, the only difference is the cylinder stroke.
    The bore is the same size.
    PK
    Apr 2012
    1999 silver 1685
    Will I need to change computers? Or will the vehicross computer work?
    May 2009
    thanks for the correction PK,
    if your 3.2 is DOHC, then no computers swap needed. just the engine
    Thanks for clearing that up...
    Apr 2012
    1999 silver 1685
    Man this is fantastic. I was thinking I would have had to buy a new motor. Great I should have my first vx up and running the end of next month
  1. Do these actually work?
    By Paul_A in forum VX Modifications...
    Last Post: 03/05/2012, 12:24 PM
  2. 4x4 won't always work!?
    By riggerr1 in forum VX Troubleshooting...
    Last Post: 02/27/2008, 12:52 PM
  3. Will it work???
    By djkymar in forum VX Talk...
    Last Post: 09/15/2007, 08:49 AM
  4. Do any of these work?1?
    Last Post: 01/18/2007, 03:11 PM
  5. would this work...
    Last Post: 11/12/2006, 12:54 AM
