Results 1 to 15 of 24
Thread: CD player
    Sep 2003
    2000,Firefox,VX,0458
    Question CD player
    My standard 6 disc CD player will not eject my CDs!
    Anyone have a suggestion?
    Jul 2002
    99 Ironman
    Do a seacrh on this, there are plenty of suggestions. Most likely you will have to bring it to the dealer. Is it still under warranty?
    Good luck getting them out. I am on my 5th CD changer, and was lucky to get the CDs ejected most of the time before replacing the dang things. The last time I did, the CDs would not come out and the dealer had to send the old changer out to recover the CDs (got 'em all back though).
    I have an Apple IPOD now, so I plan on getting the entire stereo replaced and input the IPOD to it. I already have the Trooper's cubby hole to replace the changer which is developing some bad habbits.
    My VehiCROSS
    Thanked: 7
    When all else fails and before you take it to the dealer - HIT IT.
    I had a good technique of pressing the eject button while hitting the left side of the unit. After about 10 minutes of abuse, the changer finally spit out my cd.
    That was about a year ago and I have not had a problem since. Maybe lucky I guess...
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Sep 2003
    Yeah, this CD player acted like this before and I had to pound on the side to get it to eject. Killed my hand, though.
    I even took a rubber hammer to it and nothing!
    Guess I'll try one more time and then to the dealer I go!!!!!!!!!
    Good thing I have a warranty.
    2000GREENVX0575
    It's not getting them out that's my problem. the lil bu**er seems to have a very definate music bias and has on occasion refused to take the poffered cd.
    I'll take the advise and see if thumping it soundly on the side whilst whistling dixie makes any difference.
    Sep 2003
    Uh-oh...
    Hey I'll admit, I'm not the best at fixing electronics but I think I just ran into some trouble.
    I managed to get the molding that surrounds the CD player off, I just can't seem to "unplug" the RED, White and Blue multiple wires that go into the changer at the bottom.
    They each have two "comb-like" clips that go into the casing and I can't seem to pull the unit out unless those cables are out of the damn way!
    Is the CD changer located directly under the CD player or is that something else that I'm looking at????????
    HELP!
    Sep 2003
    Ok...just dropped $170 to fix my V-cross.
    Alignment- $54.00 (coupon) They first tried to not ring up the coupon, but I caught them...sheesh! Such sneaky tactics they use.
    Battery check-$12.95
    New Serpintine belt-$35.00
    Transmission Range switch- covered by warranty
    The rest was labor.
    Here's the funny part...the CD changer is past warranty so they won't deal with it. I have 6 CDs stuck in there!
    So I either pay some shop to crack it open and fix it, or buy a new Cd changer.
    Damn!
    Jul 2002
    99 Ironman
    I have one in perfect condition if your interested we can negociate a price. Email me....
    Sep 2003
    What does Error #3 mean?
    I get this when the buttons are pushed on the CD player.
    Using the SEARCH feature at the top of every page found this:
    http://www.vehicross.info/forums/sho...ighlight=error
    Jun 2003
    2001, Vehicross blk/grey 0593
    Angry my cd player bugged out
    About 3 months ago my fully loaded cd changer stopped working. the lights on the cd select were all blinking..then a horable sound erupted from the player. javascript:smilie('')
    Took the car to stereo Dr's..they were able to save 5 of the 6 CD. Replaced it with my 30 gb I pod via fm modulator, the shop wired my car for me for 50 bucks..sounds great
    One of the guys at the shop had made the comment that these multi disk changers always breakjavascript:smilie('')
    Apr 2003
    1999 Black VehiCross 4242
    changer
    my changer just died at lunch today. i freaked out and immediately came to this site for help. i'm glad i did because even though it's still dead and i have 6 brand new cd's being held captive, at least i know now that i'm not the only one who's had trouble with their changer. i know now that they are basically trash and that i should consider it an opportunity to get a new and better system put in. my question for the forum is which systems do you recommend. are there any makes/models of aftermarket cd players and/or changers that have shown to work well with VX's? i see Pioneer a lot in these boards. is that the way to go? if so, which model(s)?
    Thanked: 7
    And I am starting to see the writing on the wall as my CD changer is just beginning to skip... only a couple of times but perhaps it is now that I should change it out.
    There is a TON on information on this subject using the Search function. I will need to know what systems can fit in the VX with out cutting into the dash or doing any modifying of the interior if that is possible.
    Aug 2003
    2001, Dragon Green #0891 [retired ;_;]
    You know, I've read all about the cd changer issue and it's made me decide, from the very beginning, to only put 5 cd's in instead of the full 6. I'm hoping its a problem with the last slot and I'll be saved the problems by simply not putting a 6th in. Anyone had problems with a non-fully loaded changer?
  1. rebuilt cd player
    By gletom in forum VX Talk...
    Last Post: 08/30/2016, 12:44 AM
  2. HDTV DVD Player
    By Mark B in forum VX Talk...
    Last Post: 11/29/2007, 10:30 AM
  3. Amazing CD Player Fix
    By LeglizHemp in forum VX Talk...
    Last Post: 02/03/2006, 09:01 PM
  4. CD player not working
    By FLBeachgirl in forum VX Troubleshooting...
    Last Post: 10/10/2005, 10:04 PM
  5. New tape player?
    By jgrish in forum VX Modifications...
    Last Post: 09/16/2005, 03:38 PM
