Results 1 to 5 of 5
Thread: replacement antennae
    2001 Ebony 0177
    well....it seems the rubber molding around the bottom of my roof antennae is shot. I have no knowledge about this at all (beyond how to put a new direct replacement one on)
    This thing looks pretty similar to the ones on Fusions and Passats and stuff. I swapped the mast for a shorter Vdub one a while back, to clear the garage screen.
    Are bases more or less all interchangeable? Beyond dimensional limitations, is there anything different between radio antennas.
    I'd like to get one of those carbon fibre shark fin ones that are BMW units (or replacements for BMW pieces)
    **one even has solar powered LEDs in it.....cooool
    ***glad I caught this before the headliner got wet and stained
    Thanx all
    Oct 2011
    1999, Black, VX, 9999
    I need one too and really like the fin idea
    Oct 2011
    http://www.visualgarage.com/home.html
    Found this link on bimmerforum...its a real fm antenna
    Feb 2011
    2001, Kaiser Silver, VX, 0871
    Thumbs up Roof Antenna Washer
    My Washer broke off also. You guys are making a big deal for nothing. If your roof antenna works fine, Just put a Black Rubber Washer underneath the Antenna Mount like I did, Problem Solved!
    JAMAS just repaired his with this stuff, said it worked great.
    http://www.vehicross.info/forums/sho...hlight=antenna
  1. My VX replacement.
    By Ebenezr in forum Chit-Chat ...
    Last Post: 11/12/2011, 07:48 AM
  2. Shock Replacement - Bilstein direct replacement?
    By Feidhlim in forum Japanese Domestic Model (JDM) VXs
    Last Post: 07/11/2009, 05:17 AM
  3. VX replacement?
    By maxw in forum VX Talk...
    Last Post: 08/13/2007, 05:58 PM
  4. FM antennae Booster Suggestion needed
    Last Post: 12/13/2005, 06:19 AM
  5. VX replacement?
    Last Post: 03/03/2005, 01:01 PM
