Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Thread: radiator to transmission hoses leaking
  1. #16
    Oct 2011
    1999, Black, VX, 9999
    Update: installed longer rubber hose and stopped the leak! Added trans fluid and now no more clunk when it downshifts from 2nd to 1st. Yes! Thank you everyone, its like you were all here handing me the wrench!
  2. #17
    Jul 2009
    2000, white, ironman, 0699
    I got a new radiator installed. A day or two later I was leaking tranny fluid. My rubber hoses were corroded and the mechanic didn't catch it. I went back and they replaced my hoses. Don't know what size they are, but they will corrode over time.
  3. #18
    Oct 2011
    My hoses were relatively new because I have an aftermarket trans cooler added for towing. The clunk sound has returned when the trans downshifts from 2nd to 1st as I come to a stop but I have NO leaks. I don't know if I need to somehow force more trans fluid into the system or just live with it. Since I have the trans cooler and longer lines, I may need more fluid than stock. My front wheel drive is not connected which could be causing the clunk. I've read on the forum that the clunk is pretty widespread and may be normal for our vehicle. I've thought about jacking up rear of vehicle and then adding fluid so that maybe there will be more room in the pan. Please comment if you have the clunk issue and have any advice.
  4. #19
    2001, Proton Yellow, #0580
    It should take more fluid but the level in the trans itself should be the same. Are you checking with the motor running and having run through the shift sequence?
    John Eaton
    Original Owner
    2001 Proton Yellow #580
    Atlanta GA
    "Metaphors be with you"
  5. #20
    Oct 2011
    Yes, we followed the directions and went through the gears.
  6. #21
    '01 Ebony #0939
    When was the last time you lubed the u-joints on your drive shaft?
  7. #22
    Oct 2011
    I've never lubed the u joints....ill add to the list....could that be the issue?
    I was thinking of jacking the rear up as high as possible and then see if I could dump more fluid in.
  8. #23
    '01 Ebony #0939
    Quote Originally Posted by bearandbee View Post
    It proved to be more of an issue than I considered at one point on the '96 Toyota Tacoma I used to have. I was feeling symptoms and hearing things that sounded serious enough that I had the Toyota dealer check things out just to be sure. I admittedly ended up feeling like something of a 4x4 newbie when they told me it was just the u-joints that needed attention, but, live and learn. There are two grease fittings on our drive shafts, one on the back u-joint (between drive shaft and rear diff), and one at the drive shaft yoke on the front.
    When dealing with auto-transmissions, I've always heard that overfilling can cause issues just the same as under filling, so I'd just stick with the service manual recommendations and add fluid at the trans fill hole on the passenger side with the vehicle in the same orientation as it will be when you're driving. When it's full enough, it will start to run out of the fill hole. (And same for the rear diff fluid if that's what you were talking about). That's just me though.
  9. #24
    2000, Ebony, VX, 0370
    Thanked: 12
    There is also a grease fitting at the slip joint at the transmission end of the rear drive shaft.
    Grease those puppies up and I bet a few of your noises will go away.
  10. #25
    2001, Dragon Green, 1342
    which is which
    Since we are on the subject of transmission lines, anyone one know which is pressure and which is return? Am installing a transmission oil cooler and new radiator, while I have the front end apart for the timing belt change. Planning on dragging a utility trailer full of my workshop in October when I move to Vegas and figure it won't hurt having this extra cooling capacity, cheap insurance I figure.
  11. #26
    '01 Ebony #0939
    That's the one I was referring to when I said yoke. Makes me question whether I've ever lubed any u-joints on the front drive shaft though.
  12. #27
    Nov 2007
    1997 SILVER
    There are a total of 3 grease nipples on the rear drive shaft.
    One on each U joint, and one on the slip yoke.
    I have not found one on the front drive shaft. (Yet).
    PK
  13. #28
    Here is a video showing the grease points
    http://m.youtube.com/watch?v=rzaNXz-ty34
  14. #29
    Oct 2011
    Thank you for the video, Etlsport! I'm sure you just saved me 3 greasy hours.
  1. transmission lines leaking
    Last Post: 08/18/2012, 05:20 PM
  2. Transmission fluid leaking
    By Exclamation in forum VX Troubleshooting...
    Last Post: 06/07/2011, 01:39 PM
  3. Silicone Radiator Hoses - can we make a bit of a group buy?
    By alanbradley in forum Japanese Domestic Model (JDM) VXs
    Last Post: 08/22/2010, 01:02 AM
  4. Pure Silicone radiator hoses now available
    By Vehi-Cross-Az in forum VX Modifications...
    Last Post: 06/27/2008, 04:49 PM
  5. leaking radiator
    By iownvx in forum VX Troubleshooting...
    Last Post: 04/03/2006, 06:14 AM
