Results 1 to 14 of 14
Thread: fog lamp install question
    Oct 2011
    1999, Black, VX, 9999
    PO ran wires from headlights to install aftermarket fog lamps. Those are now removed and my headlights are dim even though I have the brightest bulbs. He also had the ring LEDs running in Audi style under headlights. Those I'm leaving since they look cool and too much trouble to remove. I am installing TWO new sets of fog lamps / driving lights. I had planned to just run all wires into the stock fog lamp wire that's dangling behind my cladding. Or do you think its better to follow the directions and install with switches and/or switches from another Isuzu? Typing from cell phone sorry for typos.
    Lightbulb
    Install them switched separately, otherwise, they'll come on as regular clearance markers would.
    Oct 2011
    Thanks Ldub!
    Feb 2010
    2001,Kaiser,1130
    can you post any pictures of the ring LEDs? I'm curious how that looks on a VX
    2000, Ebony, VX, 0370
    Thanked: 12
    I have some installed, but one of my LED rings is out now so I'm looking for some replacements.
    Here is a shot of mine with just the rings lit:
    Oct 2011
    Both mine went out
    Thanked: 12
    I have mine wired to the original wiring for the marker lights so that they come on with the first turn of the steering column stalk. I hear, or read, somewhere that you shouldn't wire LED's directly to the 12v system because it will burn them out prematurely. Can any of you electrical geniuses confirm that?
    Oct 2011
    I wired mine per instructions in box and the dang things won't come on. The switch lights up but that's it.
    Quote Originally Posted by bearandbee View Post
    Check the ground...
    Oct 2011
    Where is best place to ground the switch under the dash?
    screw with a self tapping screw into a metal bracket. dont ever share a ground with something else. Thats what causes ghosts.
    Oct 2011
    My two switches are sharing a ground screw...should I change it?
    Jul 2009
    Depends on the grounding screw location, best place to ground under the dash is the brake pedal bracket, (big old honkin', unpainted, ugly chunk-o-steel). That sucker is GROUNDED!!
    Vixer Fixer
    Oct 2011
    Ok I got a factory switch with 5 wires and a aftermarket fog lamp switch with 3 wires....who can tell me how to install new switch? Moncha's post and pic was in Latin.
  1. WTB: JDM Fog Lamp Accessory
    By vt_maverick in forum JDM Parts & Accessories
    Last Post: 11/10/2011, 10:06 AM
  2. rear speaker install question
    Last Post: 03/05/2010, 10:00 AM
  3. Replies: 19
    Last Post: 07/31/2008, 05:44 AM
  4. OME 912 install Question
    Last Post: 07/11/2007, 11:09 AM
  5. Shocks install Question
    By BD-VX99 in forum VX Modifications...
    Last Post: 08/26/2006, 08:11 AM
