Results 1 to 9 of 9
Thread: rear end noise when coming to a stop
    Mar 2012
    sold
    is it normal to feel/hear a slight almost grabbing noise coming from the rear end when coming to a stop? im not talking about the break thing where you release the pedal after coming to a hard stop and the car drops, and its not from the front end when the tod ingages/disengages - not a grinding noise but more of a bump or like something is grabbing and only happens when slowing between 20 and 10 mph - does not feel like the trans at all i can feel the downshift smooth and completely seperate from whatever this is - i could just be paranoid but any insight is always appreciated
    '01 Ebony #0939
    Have you lubed the front and rear u-joints on your drive shaft lately?
    Mar 2012
    sold
    tried last weekend but i cant get the gall darned grease gun primed! any tricks on how to get that done again would be appreciated - didnt have a problem last time i put a tube in it but this one just doesnt want to get going
    Dec 2010
    2001 Proton Yellow VX 1268
    Check your rear axle bearings. lift up the rear end on a jack and with your hands lift up and down on the tires if there is any slop your bearings may be bad. can cause clunking in the rear end.
    Twostep (Phil)
    Mar 2012
    sold
    finally got the grease gun working and lubed the three nipples - seems to have done the trick
    You guys obviously don't turn your audio systems up nearly enough. I never hear any squeeking, clunking, whinning,...
    thats what I'm always thinking when people say they hear a little rattle in the back of their dash, or a little squeeking coming from the roof rack etc.
    CRANK UP THE TUNES!!! problem solved
    '01 Ebony #0939
    And when a person sees smoke/flames/sparks flying out of the back in the rear-view mirrors....darker window tint!!
    Haha yup youve got it!!
    All kidding aside, as long as your not billy, changing fluids and greasing joints goes a LONG way in the vx. The motor on the other hand? Eh, your just playing russian roulette there.
  1. Bad braking coming to a stop, help please??
    By VX4EJR in forum VX Troubleshooting...
    Last Post: 06/17/2016, 04:21 PM
  2. Rear door check stop
    By FlyingV77 in forum VX Troubleshooting...
    Last Post: 11/22/2010, 04:06 PM
  3. rear end noise?
    Last Post: 02/09/2010, 10:01 AM
  4. Stop!!!!
    Last Post: 02/21/2006, 07:22 AM
  5. rear bump stop extensions??
    By BBVX in forum VX Talk...
    Last Post: 07/29/2003, 12:52 PM
