Ryan, Vicki has been throwing a lot of codes lately too, but she hasn't stalled out on me yet. The four codes that I have been getting are:
P0137 - 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
P0157 - 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P1171 - Fuel System Lean During Acceleration
P0303 - Cylinder 3 Misfire Detected
I use this site http://www.obd-codes.com/ to get all of my OBDII code information. It's super helpful and gives explanations of what the codes are, what could cause them, and possible ways to fix them.
The 0137, 0157 and 1171 codes all come up together, usually under acceleration, and the site above says that one of the solutions for all three is to clean/replace the EGR valve and MAF first. That's the cheap fix, but it could be a clogged CAT that is throwing the codes too. I'll shoot for the cheap fix first to see if that does any good.
The 0303 code could also be triggered by the other three codes although it usually doesn't come up at the same time. I've already switched coil packs from one cylinder to another to see if it was a coil pack problem (it wasn't) and replaced the spark plug to see if that would fix it (it didn't). I'm hoping that by cleaning the EGR and MAF that will fix my cylinder three mis-fire issue.
Maybe some of this is going on with Little Beast? Hope it helps......some.
