Results 1 to 7 of 7
Thread: help needed
    Aug 2011
    2000, firefox, base,
    help needed
    Hi I'm Thomas Macias and i live albuquerque, NM. I bought my VX almost a year ago. I think that I'm ready for a new suspension upgrade. now i dont want to be crazy with it and have anything like a 4in lift, just a nice slight lift. Here are three that i was looking at. can you give me some feed back and let me know which one to go with and not to go with.
    thanks : }
    1.https://www.independent4x.com/mercha...products_id=13
    2.https://www.independent4x.com/mercha...products_id=12
    3.https://www.independent4x.com/mercha...roducts_id=426
    whitebread
    I cant get those links to work..
    However if you are thinking of lifting a little......
    ......this thread will give you all the various options .
    http://www.vehicross.info/forums/showthread.php?t=15476
    Think he means these:
    whitebread the feedback you're going to hear is that all you really need to lift are a taller/firmer set of coil springs (OME 912/913/919 are popular options) and a few cranks on your torsion bars (to raise the nose to match the rear). Depending on how high you go you might also want to do the diff drop (contact member tom4bren) and/or ball joint flip, but those certainly aren't required (though they may save some life on your CVs).
    If you're still interested in these packages you need to ask Indy4x which "OLD MAN EMU progressive rate Coil Springs" are included. Otherwise you probably won't be able to get much detailed feedback here.
    Actually, I'm going to leave it up to Joe Darlington to supply us with the diff drops from this point forward. The only difference between our diff drops was that I was doing 3" & he was doing 2.5". I'm pretty sure that he'd be willing to do the 3" if you asked. Needless to say, he'll be handling the crossmember drops as well so make sure you order those at the same time.
    I've got 1 set of OEM diff brackets on hand for Joe to use if needed.
    I wonder if the input/links/comments helped at all.......
    Aug 2011
    awe cool well thanks and i called and they said that it comes with the ome 912. thanks for the help : )
    Hi Whitebread..
    Ya dont need to buy a kit.
    Choose the ride height you want by looking at the examples in the thread I shared with you.
    Simply get the corresponding OME springs and fit them, then crank the torsion bars at the front to the level you like.
    Diff drop will probably not be required if you are not going super tall.
    Just keep an eye on the CV boots as they are 'used to' OEM angle and may rip as a result of increased angle...some do..some dont!
    Cheers
  1. Help needed
    By Grok in forum VX Talk...
    Last Post: 01/10/2011, 12:42 PM
  2. Upper A arm ????? Help needed
    Last Post: 12/01/2010, 06:30 PM
  3. Pic of JDM camara needed
    By Mile High VX in forum VX Talk...
    Last Post: 10/04/2010, 07:37 PM
  4. Help needed.
    By igor_san in forum VX Modifications...
    Last Post: 08/11/2009, 08:25 AM
  5. Help is needed
    Last Post: 01/25/2007, 04:44 PM
