Results 16 to 30 of 39
Thread: Engine is shot
  1. #16
    CaptnMorgan: I am sorry for your loss.
    Are there any statistics on the numbers of VXs with blown engines. Seems like this is fairly common (I recall this makes it about 5 or so engines so far, #1 in all of them). I am curious if it is the early produced models like the 99s or if it is striking randomly?????
  2. #17
    Oct 2003
    2001 Dragon green 0669
    Question
    When I took delivery on my 2001 vx today(second ownership) I grilled the dealer on the warranty not all the sales folk could agree!!!
    After they came back from the huddle they told me its 3 yr 50,000 miles bumper to bumper and 6 yrs 60,000mi drivetrain.
    Should I belive them?!
  3. #18
    Get it in writing
  4. #19
    2002, Grey, Axiom, 7578
    Smile
    Before you get it repaired... If I understood you correctly, you were wanting to trade this in anyway... How much will you take for the Vehicross right now? I need a VX for an electric conversion, so this would be perfect...
    Brent
    www.xanderstudios.com
  5. #20
    '01 Ironman #1109
    Cptnmorgan...
    I had my engine (shortblock) replaced because of #1 when it was in its early 14k. And mine was an '01 too. So, I don't think that the issue is only isolated with '99s.
    During the repair (under warranty), they replaced the shortblock and the timing belt since it was all taken apart. They assembled everything back with the other original parts. I believe that even though the incidences happen to VX owners every now and then, this is a common problem with the 3.5 and 3.2 engines which includes the Troopers and Rodeos (I think).
    If the repair is done at the dealership, then it takes about a week or two to get it rolling again after receipt of the new shortblock. Good luck if you plan to pursue any type of warranty claim with Isuzu or someone else. Let us know of the final outcome.
    www.aftershockproducts.com
  6. #21
    Mar 2003
    1998 Blue standard 1198
    Engine is shot
    Sorry to hear of your problems, it is also worrying for me and probably fellow U.K. VX owners as I doubt if any of us have any cover for this sort of problem. Looks like this is an issue for further investigation
  7. #22
    2000 Dragon Green VX 0485
    Some more info as well as some misinfo-
    http://forums.delphiforums.com/n/mb/...og&msg=1198.53
    Don't overfill crankcase as this raises crankcase pressure.
    Honda does not make the Isuzu Engine.
    Do not wait until oil is a quart low to add oil. I keep mine at top mark on dipstick at all times. I change my Filter ( Amsoil-STP) do not use Fram Filters & oil ( Synthetic )at 5000 miles.
    Dragon Bob
    This is an 18 month old post that has been re-edited & the Link does not work. Basically, I use Mobil 1 OIL Synthetic WT 5-30- Change oil & Filter every 5000 miles or 6 months which ever comes first. I clean PCV with brake cleaner & just yesterday checked & cleaned the EGR Valve. So Far So Good I don't burn any oil. I wonder if there have been any engine failures, when Synthetic oil was in use & what oil filter was installed when these failures occured. Also what is the failure rate in Japan if any & what does their warranty cover?
  8. #23
    May possibly want to look at THIS?
  9. #24
    Unhappy
    Sorry to hear of your mechanical/financial troubles. Figures it happens AFTER the warranty ends. Good luck getting it fixed, and oh yeah... if it's a choice between the Axiom engine or electric, I vote Axiom (unless the batteries can put out 230 horses).
    My VehiCROSS
  10. #25
    Batteries won't put out high hp, but they will put out phenomenal torque numbers.
  11. #26
    03' Dodge Dakota Quad Cab
    The auction states it's for the 3.2 liter engine. Will this interchange with the 3.5 liter? It says it will work for the vehicross if it's a 3.2???? The VX never had a 3.2 in the U.S..........
    3C FORMERLY VX #1876
    www.triple-cs.com
  12. #27
    Apr 2003
    That is exactly how mine happened 2 months (and 2000mi) after I got my VX
    She had 29,000 on her...
    Sounded like a very light tap at first... then 2 or so miles later.... loud clanking...
    Dealership repair, from day it was towed, to repair. was like just shy of 2 weeks ... most of it consisted of waiting for them to look at it, getting authorization, ordering the parts and waiting for them to arrive.
    Installation itself took about a day and a half.
    There were no signs of trouble prior to it going bad. It ran strong up until the noise started.
    Oh yeah, almost forgot, I had to call Isuzu directly to get my warranty transferred...
  13. #28
    Apr 2003
    1999,white,ironman,1497
    Talking 99 Engine Still going
    I have a 99 VX now with over 130,000miles....have not noted any serious engine problems....of the former type.....there is the usual mild valve noise you would have in any engine when the hoods up....
    I have been using Mobil 1 since it had 8000 miles...maybe that helped
    Of course maybe I just jinxed myself
  14. #29
    Hmmm....I was told by my dealer when I bought the Ironman that Isuzu's warranty was for 7 years or 70k on the powertrain. Who knows for sure...Dealers have lied before.
    If I was in your shoes Capt. I would investigate the "replacement" Direct Injection motor (3.5, 250 ponies vs 215).
    I would be very interested to find out what actually happened with your motor. Can you post when you find out what caused the blow up?
    Good luck
    John
  15. #30
    '99
    John, this is your correct powertrain warranty info right from the '99 warranty book.
    Here's some other related warranty stuff-
    "The Isuzu New Vehicle Limited Warranty is extended to the first owner and all subsequent owners of the vehicle during the warranty period."
    36 months or 50K miles.
    Isuzu Roadside Assistance Program is for the duration of the stated warranty- towing, flat tires, out of fuel, dead battery, and lockout. Call 1-800-444-0303.
    What is not covered: Misuse, abuse, etc. Tires.
    Surface corrosion on OTHER THAN body panels, battery, seat upholstery, A/C refrigerant, AFTER the first 12 months or 12K miles.
    "The Isuzu Limited Warranty Covering Perforation from Corrosion is extended to the first owner and all subsequent owners of the vehicle during the warranty period."
    72 months or 100K miles.
    All body sheet metal panels for perforation or "rust-through" due to corrosion.
    Warranty Covering Federal Emission Control Systems for new 1999 Isuzu Vehicles
    2 years or 24K miles.
    Air/Fuel System
    Evaporative Emission Control System
    PCV System
    EGR System
    Ignition System
    8 years or 80K miles.
    Powertrain Control Module
    Three-Way Catalytic Converter
    Warranty Covering California Emission Control Systems for new 1999 Isuzu Vehicles
    3 years or 50K miles.
    Any emission related part.
    Repairs due to Smog Check inspection failure.
    7 years or 70K miles.
    Air/Fuel System
    Catalytic Converter System
    Mark Griffin
  1. got a shot for you of my VX in a movie I was in
    Last Post: 11/16/2009, 07:17 AM
  2. Tow Shot
    Last Post: 10/25/2006, 01:38 PM
  3. Van Gogh Shot !
    Last Post: 11/02/2004, 02:37 PM
  4. Need help! CV's are shot...
    By phines in forum VX Talk...
    Last Post: 07/27/2004, 02:11 PM
  5. Hot shot non-SC?
    Last Post: 10/28/2003, 07:20 AM
