Results 1 to 15 of 16
Thread: What am I doing?
    Aug 2010
    01 Foxfire Red Mica VX 0441
    What am I doing?
    Can anyone guess what i've been doing for the past several days (my time is scarce right now) with these tools and ingredients?........
    Plastic putty knife
    Heavy duty dish soap degreaser
    Clean rags
    Water
    Denatured alcohol
    1000 grit sandpaper
    Goo off
    2001 VX
    Mods
    2008 HUMMER H3
    Quote Originally Posted by H3_VX View Post
    Plastic putty knife
    Clean rags
    Water
    Denatured alcohol
    1000 grit sandpaper
    Goo off
    sounds to me like your maybe trying to clear up some foggy headlights? but why the putty knife?
    Aug 2010
    you are correct. and holy cow i googled this method and its working like a charm after my GM dealership f'ed up myone headlight last week. the putty knife is meant to scrape off grime and some of the "film" without making scratches on the lense. what worked better was degreaser. tomorrow i'm moving onto step 4, but goo gone, degreaser and putty knife have already almost 100% corrected my lenses. i have no doubt that after the alcohol and just a tiny bit of sandpapering i'll have headlights looking brand new......and mine were AWFUL!
    PHEW...
    Thank gawd you answered that first Jack...
    ...I was going a whole different route...
    Hope they come out all "sparkly".....
    ...its a very satisfying 'chore'
    Jo
    Sep 2010
    1999 silver vx 0250
    i googled but all i found was links promoting some headlight restoration kits..anyone got a link to the above mentioned procedur?.
    Aug 2010
    Quote Originally Posted by vxfocus View Post
    I'll find it and post the link for you. Or i'll just type it up on this thread. Stay tuned.
    Aug 2010
    Here it is. Worked pretty good for me. Not perfect yet, but continuing the process again. Some of my problem is under the lense.
    http://www.ehow.com/how_7823979_repa...ight-film.html
    Now make sure you protect them so you don't have to go through all that trouble again. I'll have to post pics of my headlights but they still look perfect after the thousands and thousands of miles I spent driving across the country this summer.
    Jul 2011
    2000 Ebony Black VX
    How did you protect them Maverick?
    Mar 2012
    sold
    any thoughts on if using headlight covers would make this problem better or worse?
    2001, Dragon Green, 1342
    Quote Originally Posted by frankd14321 View Post
    Not sure how Ashley did, but I went to my local tint shop and had them covered in lexan after I had sanded and polished them. Still crystal clear after 7 years and rock chip resistant
    Jul 2004
    2000, Kaiser Silver, 0196
    Alcohol is fine, the degreaser you're using might be OK as well - depending on what's in it - hopefully no ammonia - but I definitely wouldn't use GooGone, Goof Off or any other solvent to clean those lenses! Polycarbonate is a very solvent-sensitive plastic and it doesn't tolerate NH3, terpenes or aromatics well at all. GooGone is made with citrus-based terpenes - and Goof Off reeks of xylene, which is an aromatic. Your headlights may look good for a while if you keep waxing them to fill in the surface imperfections but eventually the crazing will get bad enough that it scatters too much light and there's no fixing that - they will be ruined.
    Anything gentle enough not to harm the plastic is not going to dissolve the remnants of the old clearcoat. So you have to sand those sections anyway. It won't take much longer to go ahead and sand the whole thing. Then polish and clearcoat and you're good to go for another ten years of sparkly, maintenance-free headlight bliss. The key is protecting them with a good UV resistant clearcoat. If you don't, you'll be re-doing the job in a couple years.
    Jul 2004
    Wha...? They installed a Lexan cover/guard or are you saying they somehow coated your headlights with Lexan?
    X2...
    Quote Originally Posted by SlowPro48 View Post
    I havent clearcoated, but a good all over sanding with 1500 wet & dry..
    ....although kind of scary at first (cloudy / hazy mess!) is IMO the way to go
    to remove original coating.
    Follow this with a good mechanical buffing (drill/sponge buff pad)..
    ...using liberal amounts of Mequiars "PlastX".
    We did two VX's a couple of weeks ago...took about an hour.
    Mine had been done 3 years ago, the other VX, never.
    They both look like new.
    After this...15 mins with the buffer and PlastX every year
    will keep them pristine
    Jo
    Jul 2004
    Yeah that'll work too! I'm just lazy I guess. I'd rather spend an hour on three coats of clear (most of which is cleaning the gun) and not have to think about it again for a long while than spend 15 minutes every year polishing. Definitely agree on finishing up with 1500 grit. Makes the polishing go much quicker....
