Results 1 to 10 of 10
Thread: check engine ckeck tranny light
    Aug 2012
    1999, silver,vehicross,0555
    Check engine and check tranny lights came on today. Shifts fine, gear indicator shows correct gear.
    Any ideas?
    Thanks, chad
    You have to try harder than that...
    You need to check the codes and look them up in the service manual. Most auto part stores will check codes for free.
    Wrench
    BINGO...And before you drive it again, check the oil in the crankcase & tranny.
    They'll check the CEL codes for free but the AT codes are a different matter. AT codes are not read by the OBDII port.
    It's not that difficult to read them & if you can't find the write-up let us know. IIRC it was in a thread started by deermagnet.
    When my cel/tranny light came on they were able to read it. In my case it was a transmission slippage code that I still get from time to time during long highway drives. My trans still shifts fine and has been doing this for a couple years now.
    Aug 2012
    The code is p1870 which is transmission component slipping.
    Said it could be low fluid, or component failure. Thats not much to go on, and I was hoping that it would be a common problem that someone knew just what to do about it.
    I think that the P.O. had the codes cleared just before I showed up for it. The cel came on when I was driving it home from purchasing it. That was the egr, which is common and easy to fix. Yesterday evening the cel and check tranny light came on. I was making a scenic drive with my wife to look at the fall leaves up in the mountains. Probably a 100 mile loop or so. It may just be something I learn to live with until it starts to actually show some simptoms.
    I will pull the fill plug and make sure it is full of fluid. I am planning on doing a full filter and fluid change on the tranny this weekend.
    I appreciate the help.
    HOW TO ON CHECKING TRANNY FLUID LEVEL:
    http://www.vehicross.info/forums/sho...0&postcount=18
    Aug 2012
    Sorry, I know, I was grasping in the dark. I posted from a tablet when the light first came on.
    Aug 2012
    THX, KAT
    wish these newer units had the dipstick like my '95 trooper.
    Quote Originally Posted by chadzu View Post
    No worries, I know the feeling when you desperately want an answer so you can stop thinking about it. I'm glad it wasn't a major issue.
    ... and welcome to the community.
  1. Low tranny fluid=flashing check trans light!
    Last Post: 01/27/2009, 05:25 PM
  2. Check Engine Light Is On????
    By littlewing2 in forum VX Troubleshooting...
    Last Post: 03/14/2008, 08:00 AM
  3. Check Engine Light
    Last Post: 11/05/2007, 09:11 AM
  4. Check Engine light
    By crager34 in forum VX Troubleshooting...
    Last Post: 03/22/2004, 04:35 AM
  5. Check engine light...
    By ScubaSteve in forum VX Talk...
    Last Post: 10/07/2003, 05:07 PM
