Results 1 to 15 of 20
Thread: Nissan Titan 17" rims fit VX?
    Sep 2011
    1999, silver, 0457
    Trying to figure out if some Nissan Titan 17" rims will fit the VX? I've been reading through threads. I saw one about Nissan Armada rims but with no conclusion, I will continue to research.
    Sep 2011
    1999, silver, 0457
    Here are the specs I found for the rims:
    Bolt Pattern: 6x5.5"
    Offset: +30mm
    OEM Part Number: 403007S310
    Part Number: 62435
    Here is a link with a lot of pictures: http://www.ebay.com/itm/17-NISSAN-TI...-/270762911323
    You'll have to contact the seller & have them measure the diameter of the center bore.
    for our VX, "the oem wheel is a 6 on 5.5 bolt pattern, 38 mm positive offset with 108 mm center bore"
    Rumor has it that 100mm center bore will fit but several members have had to have brand new rims machined for clearance before they could be mounted.
    Mar 2012
    sold
    curious why you would want 17" nissan wheels on your vx...
    Sep 2011
    1999, silver, 0457
    Mainly for the larger tire size (285/70/17). Which is my other question, could I fit this size on my VX with some trimming (no lift)?
    Mar 2012
    sold
    why not get 16" vx wheels?
    Sep 2011
    1999, silver, 0457
    I have 16" stock vx wheels. Stock tire size 245/70/16, isn't the largest I can go 265/70/16?
    Looks like the center bore of a Nissan Titan is 77.8mm. According to this thread: http://www.vehicross.info/forums/showthread.php?t=19383 our center bore is actually 100mm not 108mm. So I would have to get the Titan rims machined to 100mm...
    Mar 2012
    sold
    i get it you want wider - the best mudding vehicle i ever say was a stock 1940's army jeep w/ knubby pizza cutter tires - he ended up pulling everyone else with those giant balloon tires and suped up motors out of the mud after they got stuck
    It depends on the slop.
    Skinny tires are great for cutting through the slop down to a more firm surface to bite on ... if there is firm stuff underneath the layer of slop.
    If the layer of slop is deeper than the ground clearance of the vehicle, then you're better off with the floatation of the bigger/wider tires.
    Either way - you still need the wide lug spacing of mud tires in order for the tires to eject the buildup of mud.
    Feb 2009
    1999,silver, 1516
    And if it's gumbo mud, you need some major wheel-speed to fling the mud out of the treads, and all over your friends...
    We GOTTA wheel together sometime
    Sep 2011
    1999, silver, 0457
    Just found these http://minneapolis.craigslist.org/ws...271787457.html would I need to lift my vx to fit these or just some cladding trim?
    Never mind, found the answer here: http://www.vehicross.info/forums/sho...gest+tire+lift
    2000 IronMan #11
    Nissan, Toyota truck wheels will fit. From what I know, their bores are larger than the Chevy lug pattern like ours.
    17 Rim - good choice. There are a lot of 17 tires out right now.
    I have 255/75-17 MT https://treadwright.com/p-76-255-75r17-guard-dog-c.aspx
    Sep 2011
    1999, silver, 0457
    Titan center bore diameter is 77.8mm...so to small. I like those tires!
    Quote Originally Posted by cheetah2390 View Post
    Im sorry cheetah, but I dont understand your logic? You want to fit bigger tires on your vx without a lift, thats fine, but changing the rim size isnt gonna provide a bigger fender well to put big tires in? In fact it will make the tire smaller and the rim bigger?
    I believe you are correct that 265 is the biggest that will fit without a lift, but the outside diameter will be the same on a 16 or 17" rim, plus you have to buy new wheels?
  1. Anybody Ever Seen These 14" Isuzu Rims?
    By vt_maverick in forum Chit-Chat ...
    Last Post: 11/01/2013, 11:23 AM
  2. Tires for 16" Rims
    By dietz99vcross in forum VX Talk...
    Last Post: 02/04/2008, 11:41 AM
  3. After market rims 20"
    By sam in forum VX Modifications...
    Last Post: 10/31/2005, 04:32 PM
  4. 18" Rims & Tires: FS
    By Child's Play in forum VX Talk...
    Last Post: 01/12/2005, 09:18 PM
  5. WOW..285's fit my 18" rims??
    Last Post: 01/07/2005, 09:01 AM
