Results 1 to 9 of 9
Thread: Timing Belt Kit
    2001 Proton VX, 0744
    Timing Belt Kit
    Found this Timing Belt Kit - Has anyone bought this one?
    Any thoughts?
    GMB Evergreen TBK303VC Isuzu 6VD1 6VE1 Timing Belt Kit w/ Valve Cover & Water Pump
    I found it on EBAY for 152.00 - do you guys think it is missing anything?
    http://www.amazon.com/Evergreen-TBK3...1&s=automotive
    "KILLER BEE" :
    2001, Proton Yellow, #0580
    It looks similar to the kit I used - beware that there are some pitfalls to the install (timing marks aren't right) and the idler pulley in my kit had the wrong off-set. Here's the write-up I did:
    http://vehicross.blogspot.com/2012/0...ming-belt.html
    -- John
    Jun 2007
    2001, Proton
    similar to mine
    My components were from Japan as well. The best option is look at the weight for shipping. The cheap stuff is pounds lighter.
    Carter Pewterschmidt
    I am getting ready to do my timing belt/water pump in the next couple months (I figure at 145,000 miles it's about due ). In my opinion you will do the job more often with cheap aftermarket parts...not something I want to do. I will spend the little bit extra for quality oem parts so I don't have to repeat the job in 6 months. Merlin should be hearing from me soon
    If it were an easy job I don't mind cheaper aftermarket stuff....but something that requires this type of time/effort I want to last. Just my two cents.
    PK in Australia also got a kit off ebay about a year ago.
    Ebay seller ID - scpltd123 =Small Car Parts Ltd
    He said it appeared to be of good quality.
    Hey PK, after a year, any issues?
    Hee's PKs thread about it:
    http://www.vehicross.info/forums/sho...MING+BELT+EBAY
    Feb 2004
    '01 Ebony #0830
    Beware of non-OEM timing belt tensioners. They can fail, causing a similar symptom/sound to rod knock or spun bearing.
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Aug 2010
    01 Foxfire Red Mica VX 0441
    Looking at Gates timing kit and water pump. I've heard they're better than OEM belts in most cases.
    http://www.ebay.com/itm/Gates-TCKWP3...mp;amp;vxp=mtr
    2001 VX
    Mods
    2008 HUMMER H3
    I ended up getting everything through Merlin back tn because I did not want to take a chance.
    Aug 2010
    wow, 145k on the same belt. Isn't that unusual?
  1. Did I screw up my timing? Timing belt replacement
    By workmeistr in forum VX Troubleshooting...
    Last Post: 04/13/2015, 07:26 AM
  2. Timing Belt on the 3.2
    By alterastro in forum United Kingdom Special Topics
    Last Post: 01/17/2010, 12:55 PM
  3. Timing belt replacement and timing videos
    By deermagnet in forum General Tips...
    Last Post: 11/26/2007, 08:09 PM
  4. Timing belt replacement and timing videos
    By deermagnet in forum Archives
  5. Timing belt ???
    Last Post: 12/15/2005, 10:34 AM
