35's and standard gearing is NOT a "No Go" IMO...
I've been driving on 35's for approx 3 years with the OEM diffs...including Moab twice.
Yes, there are changes to acceleration and shift points...
....and your speedo will read under.
But its perfectly do-able with a little driver modification!!
The 4.77's are difficult to find...but not impossible.
I have found two matched sets in the past 1.5 years......with help from friends here
and also a simple " 4.77's Wanted" post over at the Planet.
I blew the back one up from the original set immediately ( bad seal)....
.......hence searched for a replacement set.
I will be putting the 4.77's on with my 35's...but its more because I got a set with Aussie Lockers front and back...than a gearing issue for me.
Why not start a search now for the 4.77's....go with 35's....
....and swap out the OEM diffs when ya find the 4.77's?
Just a thought ....
And
....a body lift is not required for 35's...given some grinding and hammering.
Plus..no body lift helps keep Center of Gravity lower.
Jo
