Results 1 to 7 of 7
Thread: trans check???
    Apr 2012
    1999 silver 1685
    trans check???
    How do you check the fluid level in the trans? The vx i have only has 84000 miles and it feels like it is low on fluid. I know its closed but is there a screw on the side of the trans or something???
    1999,silver,vehicross,1891
    check
    yep, there is a drain and a fill screw; gotta start it on level ground and open fill screw, some fluid should run out,if no fluid runs out, its low
    Oct 2011
    1999, Black, VX, 9999
    Make sure your engine is cold. Wear rubber gloves, lots if rags and an old long sleeve tshirt. There are step by step instructions in the forum if you are low, they are a must read.
    Mar 2012
    sold
    engine must be running when you check - correct? and i know on any other vehicle i have owned you must go slowly through all the gears before checking as well for accurate readings - i searched and searched but never could find a simple walkthrough to check the fluid, only flush and change
    Jul 2009
    Yes, engine must be running at idle and the trans fluid temp needs to be between 90 and 135 degrees F. You can check it with a temp gun pointed at the main trans pan or with a scan tool if you have one. Fill through the overfill screw opening (top plug) until fluid runs out and immediately replace overfill plug. Torque to 25 lb ft. Done!
    Vixer Fixer
    Jul 2009
    Here's a great how to showing the refill process along with a filter change!
    http://www.vehicross.info/misc/pdf_files/ATF_Change.pdf
    Apr 2012
    1999 silver 1685
    thank you guys for the help. I reallt needed this. Now once i get the gas leak fixed im on it.
  1. Trans fluid??
    Last Post: 05/05/2014, 02:39 PM
  2. Low tranny fluid=flashing check trans light!
    Last Post: 01/27/2009, 05:25 PM
  3. Check Trans Light
    By Bieredalsace in forum VX Troubleshooting...
    Last Post: 10/16/2008, 04:09 PM
  4. Trans cooler.
    Last Post: 09/30/2004, 08:54 AM
  5. Check Trans w/code P1870
    By Reg Hinnant in forum VX Troubleshooting...
    Last Post: 07/12/2004, 10:28 PM
