Results 1 to 5 of 5
Thread: newly installed engine won't start
    Feb 2010
    1999 Ironman,#1-1767, #2-1326
    OK, have engine that was rebuilt got from guy in Louisville,KY. Have it installed now, I am getting no click at starter. Have new battery, just the engine was installed. If jump relay get 12V at small wire, have relay I know is good, took starter and it checkes good. I am taking readings from relay to engine and get 12V so know engine is grounded. What else can I look at? Does the security system have anything to do with power getting to the relays? Car has been sitting for 6/7 years, was inside for all but last year.
    Sep 2010
    2001 kaizer vx
    anti teft disconnecting starter relay.
    had no start problem with poor battery terminals as well - was no power at fuse-relay box.
    gizmo,
    The manual for the security system references the starter cutout. Unfortunately it only lists the solution of overriding the cutout by disarming the system via the key FOB. They don't list any other solutions so if you don't have a FOB for that vehicle, you may have to program one of the ones from your other VX to this one.
    EDIT:
    The only other solution I could find when googling was to "disconnect the cable from the security system brain under the dash". I don't know enough about the system to tell you if that would work or not.
    EDIT again:
    The one thing that I have heard for sure is that disconnecting the battery does NOT reset this security function.
    Feb 2010
    OK so I have a FOB for this one so will have to program it. Thanks will let know, have been sick and don't have energy to do it at this time.
    Quote Originally Posted by yellowgizmo99 View Post
    Man...do I hear THAT...had the same "what's goin' round" a couple wks ago.
    Just now starting to feel 98%...
    Get well soon! ( & get some antibiotics)
  1. new engine start up?
    By vxfocus in forum VX Troubleshooting...
    Last Post: 06/30/2013, 07:55 PM
  2. Engine Rolls Over, Won't Start
    By ShadowRider in forum VX Troubleshooting...
    Last Post: 03/02/2009, 05:30 PM
  3. Remote Start installed / TOD problem
    By cyronman in forum VX Troubleshooting...
    Last Post: 06/01/2008, 08:38 PM
  4. Auto Start installed.
    By NJVX in forum VX Talk...
    Last Post: 12/15/2004, 05:16 PM
  5. Engine won,t start...HELP
    Last Post: 03/05/2003, 09:51 AM
