Results 1 to 6 of 6
Thread: VX A/C Compressor issue need help!!
    Oct 2007
    2000 Victory White Ironman
    Unhappy VX A/C Compressor issue need help!!
    I just replaced the ac compressor in my VX it worked great for about a week. Now I am not getting power the the compressor so no ac. I have checked the A/C relay in the fuse box under hood and it's good any suggestions would be greatly appreciated.
    Jun 2003
    1999 Silver #1036
    I would be willing to bet that your A/C system is out of freon. When the freon pressure drops, the compressor will not turn on. I had the same problem after a new compressor was installed. Worked for a week or so and then died. It was a small leak at a fitting, had it repaired and refilled---works just fine.
    Bob Seidman
    1999 VX Silver #1036 (born on 5/18/99)
    1980 308 Ferrari GTS Red #31495
    1959 Austin Healey Bugeye Sprite
    2009 Smart Passion Coupe
    Oct 2007
    thank you seidmanrob seems that is the issue
    Jun 2003
    1999 Silver #1036
    Glad to be of assistance, I just love this forum.
    Mar 2012
    sold
    did you put it on yourself? the system has to be checked for leaks then charged - there is also a drier and orefice tube they suggest be changed anytime you open the system
    Oct 2007
    Yes I changed that all myself and evacuated the system. Charged found a leak replaced new o-ring re did it all again and no leak. now a leak somewhere. I bought a new compressor from discount compressor looked exactly the same as oem.
  1. A/C Compressor
    By Seidmanrob in forum VX Troubleshooting...
    Last Post: 05/30/2015, 11:17 AM
  2. a/c compressor
    By vxfocus in forum VX Troubleshooting...
    Last Post: 08/22/2012, 03:25 PM
  3. a/c compressor
    Last Post: 06/16/2012, 10:26 AM
  4. Compressor or Jumpre/Compressor?
    By RabidPony in forum VX Talk...
    Last Post: 08/10/2010, 12:41 PM
  5. A/C compressor fan
    Last Post: 04/07/2010, 05:18 AM
