http://www.vehicross.info/gallery/sh...papass=&sort=4
right now, my free switch plate is being used and i have my fogs on a AM switch at the bottom of the dash cover.
where can i get this expansion pack?
http://club.vmag.com/ubb/Forum39/HTML/003664.html1. Fuzzy Hole replacement switch bezel p/n 8-97107-569-0 ($12.26)
2. Tailgate Release switch (from 95.5-97 Rodeo) p/n 8-97093-960-3 ($41.67)
3. Foglight switch (from 98-newer Rodeo) p/n 8-97125-279-2 ($18.73)
4. Rear defrost switch (from 2000-newer Rodeo) p/n 8-97239-232-0 ($20.95)
thanks, been scanning through old posts to find this, but no luck.
wouldnt happen to have the part number for blank switch covers?
I'm looking into this for fog lights and the rear popper, but I dont know what the blank part number is. I actually book marked this mod so I wouldn't have to remember which forum it was on You might give a call over to Merlin at st charles and see if he can get you the part number
http://isuzu.stcharlesauto.com/parts...rts_department
Would you have a number for the switch for TOD disconnect from a Trooper or Rodeo?
Thanks, Roy
Roy, I called St Charles to try to find out, as I want one too...
Came up with p/n 8971426561/ Switch Transfer for TOD (for 97 to newer Trooper)
$69.48
Does anyone have a trooper with this switch?
It is 2nd switch from far left above the heating controls.
Sounds like it might fit the bill, but damm that is allot of cash for a crazy switch, then again I just paid 40 bucks for one that says tailgate open on it.
I just ordered my fuzzy hole replacement with fog lights and tailgate opener!
Apostle:
Block off plates (Switch Blanks) 8-97081-617-1 ($2.04)
-Dave
Thanks, Roy
newthings are you not roy? I called them, was telling you I thought... hehehe
using the word "switch"Originally posted by Apostle
I came up with these results..
http://www.vehicross.info/forums/sea...der=descending
leading to this thread...
http://www.vehicross.info/forums/sho...ghlight=switch Your info would be the 4th listed
Scott / moncha.com
