Results 1 to 7 of 7
Thread: Exhaust flange gasket
    Jul 2010
    1999,silver,VX,0118 & 1144
    Simple one...is it easy to change? Is there an easy way..
    Dec 2012
    1999 silver #1820
    On mine the drivers side one was easier because of the flex joint in the pipe, the passenger one took alot more wrestling and cursing!
    Nov 2012
    Which flange are you talking about? The three bolt flange at the header is a chore. IFRC it uses 17mm bolts and were not easy to get to. I used an extra-long socket extender with a swivel joint at the socket and a cheater bar to break it loose. Definitely left some skin on the underside of the car. The other flanges using two 14mm bolt were fairly easy as long as you can get the bolts loose.
    Mar 2012
    sold
    i need to get that apart as well so i can get to my starter - looks like a serious pita so i might just bring it to exhaust guy he said it would be no prob when he looked at it
    Jul 2010
    Yes the 3 bolt . So it's easier from under than thru wheel well? I just want to Get loose enough to slide new one in. Hopefully not breaking Exh. bolts.. I always hate anything to do with exhaust near heads...The fear of SNAP!!!
    Jul 2010
    Oh, as for other flanges my bolts were welded so an air grinder with small disc helped.
    Nov 2012
    Quote Originally Posted by jmayer40 View Post
    I was doing this on a '98 Trooper. I haven't done my VX yet. I assume the access is the same. It might be possible through the wheel well but those inside bolts would be a MF.
  1. Exhaust Gasket Leaks
    By iyafyl in forum VX Troubleshooting...
    Last Post: 06/12/2013, 07:41 AM
  2. emission warranty ?? exhaust flange on converter
    By Dean68 in forum VX Troubleshooting...
    Last Post: 07/02/2009, 08:31 AM
  3. Replies: 4
    Last Post: 04/05/2007, 04:06 PM
  4. egr gasket
    Last Post: 11/05/2006, 02:42 PM
  5. Exhaust flange (weld) problems
    By AlaskaVX in forum VX Troubleshooting...
    Last Post: 09/20/2005, 10:05 AM
