Results 1 to 7 of 7
Thread: PLEASE respond so i will have a car to drive tomorrow
    May 2003
    99 black vehicross 0000
    i drained my tansission fluid yesterday without realizing there was no dipstick to refill it. to refill into the fill plug what eactly do you have to use and how. right now i have a pump that connects to the transmission fluid bottle, but the end that the fluid comes out has a plastic thing that is to big to fit up into the fill hole. i tried to pump some into the bottom of the hole but it just drained back out. please help
    What kind of pump? Hand or electric? Can you cut the "big thing" off the end of the pump hose and keep proper pump functionality? Maybe the thing is a check valve to prevent backflow into the pump, which is not critical for this situation.
    Ideally you want a hand suction pump that looks kind of like a grease gun. You pull back the plunger to fill from bottle, then put hose in upper fill hole and push the plunger.
    In a pinch, sometimes you can use an empty, clean rear axle fluid bottle. The kind that comes with a pointed tip that you cut to desired size. Get a length of 3/8" I.D. hose (about 2 feet). Cut the tip from the axle fluid bottle so that the 3/8 hose fits tightly. Cut the hose to the shortest length that will allow you to manipulate the bottle to a point higher than the fill hole, under the truck. Fill the axle fluid bottle with your trans fluid and attach cap/ hose assembly. With the hose in the hole, begin to squeeze or crush the axle fluid bottle to fill the trans etc. When the container is empty, you can reshape and refill it several times, but watch for leaks.
    2001 Proton VX 0790
    6 ft of 3/8 hose, and a funnel it fits on. Stick the hose in fill hole, and stand next to the car holding the funnel. fill till it comes out, then top it off again running. fluid it checked at idle, hot in neutral.
    Be careful not to get run over, M'kay?
    John C.
    or
    What he ^^^ said. Lay a container or some paper towels where the fluid will spill when it overfills.
    Jun 2003
    1999 Victory Ironman 1703
    Just in case, you are filling into the filler hole and not the drain, right?
    Jonathan
    May 2003
    thanks
    thanks for the help. I ended up connecting a smaller hose to the hose i had and pumped it in. I also topped it off while it was running. Does anybody know where i can get a used service manual?
    Apr 2003
    1999 Astral Silver 1222
    Cool. A fourth VX in Bama. 1 white, 1 black, 2 silvers. You wont stop hearing "what in da wurld is dat der little truck?" LOL
  1. Mechanics please respond is this normal? Pics.....
    By LittleBeast in forum VX Troubleshooting...
    Last Post: 02/03/2013, 07:02 AM
  2. To the diff droppers - please respond
    Last Post: 03/10/2009, 03:00 PM
  3. Moab 04 Hotel Interest? Pls Respond
    By Tone in forum Moab 'Zu Zoo VII May 12-15, 2004
    Last Post: 05/02/2004, 10:07 PM
  4. Az. VXers Respond!!!
    Last Post: 02/19/2004, 02:02 PM
  5. Superchargers respond ASAP
    By AlaskaVX in forum VX Troubleshooting...
    Last Post: 07/10/2003, 11:24 PM
