Results 1 to 3 of 3
Thread: Transmission Pan Leak
    Feb 2011
    2001, Kaiser Silver, VX, 0871
    Wrench Transmission Pan Leak
    Has anyone used Form A Gasket Silicone Instead of the OEM CORK Transmission Pan Gasket? It seems The Cork Gaskets Eventually Start To Leak Even If They Are Retightened. Maybe I Could Find A Replacement Transmission Gasket In RUBBER?
    Feb 2011
    Thumbs up Transmission Main Pan Leak
    Problem Solved, Removed The Cork Pan Gasket & Used Permatex Extra Strenght GREY Silicone !
    1999,silver,vehicross,1891
    agree that permatex stuff works great; I've been using rubber gaskets from rockauto; no leaks; had several on their over the year, especially late last year when I had total tranny failure then rebuild; needed some time away; bottom line, tranny running great, just slight leak from new intercooler; bypassed the radiator all together, the intercooler section of the radiator is a joke if you examine it internally
  1. Selector Shaft Seal: Transmission Leak
    Last Post: 11/15/2014, 08:15 PM
  2. Transmission Cooler Nagging Leak
    Last Post: 01/01/2014, 05:10 AM
  3. Transmission cooling line leak
    By Autor in forum General Tips...
    Last Post: 08/15/2013, 11:30 AM
  4. Transmission Case Gasket Leak...
    By ron in forum VX Talk...
    Last Post: 06/18/2011, 07:50 PM
  5. Transmission fluid Leak from small hole
    By Troysaddress in forum VX Troubleshooting...
    Last Post: 07/30/2010, 11:13 PM
