Results 1 to 15 of 15
Thread: Help! How far can I tweak my torsion bars?
    Technically you can set the torsion bars as much as the suspension will travel. Jack up the front of the VX and measure the distance when the wheels are at full droop and that will be your full measurement. Even if the torsion bar adjustment bolt tightens to a stop, you can remove the assembly & re-index the torsion bar to continue lift.
    I had the VX at full suspension lift before and it was really bumpy. With the body lift, I measure 25" to the cladding. If you subtract the BL, we both measure 22" to the wheel well. From my experience recently with SFIFS, I would say you have about 2.5" before you've reach the IFS bump stops.
    Wrench
    I'll add that at full suspension lift, your 1/2 shaft angles will be, like....totally heinous dude...
    And CV replacement will be much more freqently...
    Unless you install diff drop brackets.
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    Mine are sitting 4 turns from max (I think). And, it doesn't seem "lifted" over stock height. Alignment showed everything in correct position.
    Are you saying those last 4 turns make that much difference?
    How can I tell if I'm higher than stock height? (in the front).
  1. Cranking torsion bars too much??
    By Boonetown123 in forum VX Troubleshooting...
    Last Post: 08/31/2014, 12:43 PM
  2. Torsion bars
    By ohiovx in forum VX Modifications...
    Last Post: 02/05/2014, 02:50 PM
  3. Cranking the torsion bars...
    By espidus in forum VX Modifications...
    Last Post: 04/12/2012, 10:09 PM
  4. HD Torsion Bars: Anyone tried them?
    Last Post: 02/01/2012, 10:14 AM
  5. Torsion Bars
    By joesvx in forum VX Modifications...
    Last Post: 10/24/2003, 07:54 AM
