Results 1 to 12 of 12
Thread: Split CV Boots
    2000 IronMan #11
    Split CV Boots
    Has anyone tried the split cv boots that slide over top of the joint and weld together with glue?
    Like this one?
    http://www.dormanproducts.com/p-2627-614-434.aspx
    This says that it is not compatible with the VX though, but listed for reference.
    However if you check the mecatech/other dormans that fit the VX the same boot also fits another near 1000 cars via Oreily auto parts website.
    http://www.oreillyauto.com/site/c/de...eyword=cv+boot
    I personally would not use them. I look at them as more of a temporary fix...something to hold you over until you can do it right.
    Wrench
    X 2...a band-aid solution...
    Jun 2003
    1999 Victory Ironman 1703
    Don't do it.
    I hafta agree. If your OEM boots split, it's not likely that a glued together boot will last more than a few days.
    BTW, MechaTech & Dorman boots didn't last for me either. They guy at the axle shop put on some boots imported from Canada that finally did the trick (look just like OEM). Unfortunately, I was never able to find them retail.
    Someone posted a long time ago that Advance Auto over the counter boots are incredibly beefy & hold up well (also look like OEM). They are a lot cheaper than MechaTech.
    2001, Proton Yellow, #0580
    I believe they're intended to be a temporary fix.
    May 2007
    1999 Black Rodeo
    Surprising. I put Dorman boots on my rodeo when I first bought it about 7 years ago and they are still doing fine.
    --Dave
    I'm with you Dave...
    Quote Originally Posted by Gizmo42 View Post
    ....after my OEM set split just after lifting ( normal!) I fitted Dorman...
    ....and 6 years later have only replaced one...cause I tore it on a rock.
    I think these split boots are good emergency options...but then so is Duct tape!!
    Jo
    Jo
    +2, Ripped my OEM boots after initial lift. Replaced with mecatech right before Moab 2009 and ripped both inner boots the first day and dust/sand destroyed my CVs.
    Now I run EMPI brand boots and straighter half shafts. No CV problems in 2 years.
    We'll all hafta agree to disagree on the whole CV issue. There doesn't seem to be any rhyme or reason to it: lift/no lift, Dorman, MechaTech, diff drop/or not.
    Trial & error seem to be the only solution till you get to works for you. Unfortunate for me the trial consisted of 4 sets of boots, 2 sets of half shafts & a diff drop before I finally settled on something that lasts.
    2000 IronMan #11
    I figured the opinions would be bad in these! I just don't see how they could work! I kinda want to try just for the heck of it. But it would like wiping my *** with a $20 bill and a few singles!
    I split an outer one and not sure how long ago! It's not a bad split but....
    May 2003
    Cool
    Recently split the outer driver-side original boot...can't complain after them lasting 13yrs & 157k miles, surviving a trip to Moab, plus 2" lift done years ago. I ended up using it as an excuse to finally install my diff-drop brackets I bought 4 years ago (1" drop) plus replaced all cv boots with Dorman but used the silicone (gray) ones.
  1. What Do You Get When You Split a Proton?
    By bartmanS4 in forum VX Talk...
    Last Post: 02/18/2015, 12:08 PM
  2. TOD 15/85 split problem
    By JNUVX in forum VX Modifications...
    Last Post: 01/29/2010, 11:39 AM
  3. PO's mod? Turn signal wiring split for window washer lights
    By Osteomata in forum VX Modifications...
    Last Post: 04/08/2009, 11:45 AM
  4. advice on cv boots
    By 99vx in forum VX Talk...
    Last Post: 10/09/2003, 06:07 PM
  5. Modifications done to instument cluster (From a split thread)
    By Raque Thomas in forum VX Modifications...
    Last Post: 09/26/2003, 06:18 AM
