Results 1 to 7 of 7
Thread: Front right end noise
    Aug 2011
    2000, firefox, base,
    Angry Front right end noise
    Hi all so it seems that i am having a very bothering sound coming from the front right end of my VX. I have taken it to a couple of mechanics including "MIDAS" so far and have had no luck lol.
    I am just kind of worried that his sound is going to turn in to a big problem for me and would like some help...
    i found this thread on the forum...
    http://www.vehicross.info/forums/showthread.php?t=7330
    should i take it to a drive shaft specialist?
    This sound only started when I put the OME 2.5 lift on the truck.
    Now i know the shop that i had install the lift had to do a couple of turns of the torsion bar to level out the VX.
    is it recommended to maybe buy some of these...?
    https://www.independent4x.com/mercha...roducts_id=222
    suggestion
    whitebread
    2001, Ebony Black, 1153
    What does it sound like? A pop, a grind, a whine, an exhaust leak, a high pitched chirp, a constant whine, pop when turning, clatter on start up, hiss when accelerating, what kind of sound are you talking about, and when does it make this noise?
    X2
    We've seen those irritating noises be caused by everything from bad CVs, to worn U-Joints, to exhaust heat shields, to loose tranny mounts, to bad AC blowers, to rubbing skid plates, & of course the ubiquitous collection of acorns I found under my hood.
    Aug 2011
    Its like a grinding sound when I decelerate from 40 miles an hour. the sound will go away if I press on the gas at all. Its exactly the problem that the VX'ers were talking about in that thread that I included on the original post
    Have you checked your CV boots lately. It sounds to me like maybe your inner CVs are toast.
    That is a common "sound" after a VX lift. U joints do not need changed to correct this. My VX has been lifted for 8+ years with that deceleration noise...no harm. If it bothers you enough the fix is to replace your lower links with adjustable ones (indy4x sales them or you can have yours modified at 4wheel drive fabrication shop). The noise is caused by the front and rear angles on the rear driveshaft u joints no longer being the same.
    Aug 2011
    Okay my original machanic go it..
    It ended up being my passenger Side tie rod and the cv axle
  1. Popping Noise in Front When Moving
    By bartmanS4 in forum Ldub's After Midnight Topics
    Last Post: 03/23/2015, 03:42 PM
  2. front end noise
    By takentolightly in forum VX Troubleshooting...
    Last Post: 12/01/2011, 12:41 PM
  3. grinding noise from front right wheel
    By castigan in forum VX Troubleshooting...
    Last Post: 07/08/2011, 12:53 PM
  4. weird sqeaky noise in the front end
    By protonvxmatt in forum VX Troubleshooting...
    Last Post: 07/18/2006, 07:58 AM
  5. Front end noise?
    By billh23 in forum VX Troubleshooting...
    Last Post: 08/10/2005, 02:13 AM
