Results 1 to 5 of 5
Thread: Starter Woes
    Oct 2012
    2001, Silver, 0634
    Starter Woes
    I have seen several posts on checking on/replacing the starter by screwing with the exhaust. Is it possible to check on the starter wiring and/or replace the starter through the driver side wheel well? I'm getting the once click and nada syndrome and I have checked everything but the hard connections on the starter. Just wanted to ask before I get at it.
    Oct 2012
    2001, Silver, 0634
    Dang. This is one thing that stinks about living in the Alaska time zone....by the time you get home and can log in to ask a question, everybody is asleep.
    Don't have an answer about getting to and checking the starter. But, have you thoroughly checked your battery cables and terminals for corrosion? The corrosion.can travel down into the wire under the casing which will cause the symptoms you describe.
    Oct 2012
    2001, Silver, 0634
    yeah....I had to cut off about an inch of batter cable to get past the corrosion. I replaced the terminals and all of that checks out. I'm thinking I have either a bad starter or a loose wire on the starter that is intermittently connecting.
    Mar 2012
    sold
    make sure you order the starter using youf model # and not just order it for a vehicross or you will get the wrong one - mine said it was for an acura
  1. QUESTION: Engaging Starter from Starter Relay
    By Joe_Black in forum VX Troubleshooting...
    Last Post: 06/04/2015, 07:10 PM
  2. Starter or much worse??
    Last Post: 08/20/2013, 06:42 PM
  3. Replacing Starter
    By Vehi-Cross-Az in forum VX Troubleshooting...
    Last Post: 02/03/2009, 02:55 AM
  4. Remote starter
    Last Post: 06/13/2007, 09:13 PM
  5. Remote starter
    By vxkween in forum VX Modifications...
    Last Post: 07/10/2004, 07:13 PM
