Results 1 to 15 of 18
Thread: Heavy Hood...what should I do?
    '01, Proton, VehiCROSS, 0229
    Thanked: 15
    Now that the hood's underside has Dynomat Extreme (heavy), 1/8" DynaPadding, and a brand new OEM Hood Insulator, and Hood Insert that's Carbon Fiber...
    the hood is VERY heavy, I mean... heavy.
    Do I need to do any kind of mod now? Like something to the lock that holds it in place or just anything? Do I need to do anything to compensate for the much heavier hood?
    Just wonderin...
    Ty
    Aug 2008
    Simple-- Do more push-ups!!!
    Jun 2010
    99, Silver, 1784
    Absolutely. Get stiffer front shocks, and the HD torsion bars from Indy4x4, and definitely a realignment as the increased weight might have pressed yours out of alignment. It's important.
    That. And the push-ups.
    -V
    -VI VX VNIVERSVM VIVVS VICI-
    Thanked: 15
    Wow Riff Raff
    -V
    OK... so I can't continue to use the front stock shocks?
    I had no idea... thanks
    Jun 2010
    99, Silver, 1784
    Ty, do I look like I'm serious?
    Listen to Riff, he's got you covered. You're all good, man.
    -V
    Thanked: 15
    Speed holes!
    Oct 2012
    2001, Proton, 0586
    Why would you put dynomat on your hood?
    And shouldn't CF inset be lighter?
    Jan 2013
    2001,custom,#0947
    or hood ups hajah
    2001,FOX FIRE RED MICA,0251
    Quote Originally Posted by Leon R View Post
    Agreed,and that engine bay is going to get extremely hot I believe.
    -V
    LMAO
    Nice one V!!!
    Jul 2009
    That extra weight should keep the front end more planted without the need for aero...sorry, too much Monaco F1 and Indy 500 this weekend!
    Vixer Fixer
    01, LineX tan/black, 1055
    I would agree about the hot engine bay. Our confined bays already run fairly hot. Did you really have that much engine noise? I prefer to hear every tick and clank so I can immediately tell if something is wrong.
    As for weight, mine is heavy now as well, with the LineX. I don't know if the OEM prop will hold up, I can see it flex when I prop the hood.
    Thanked: 15
    I hadn't thought of the temp in there.... but it's to late. The deed is done. I could, however, remove the OEM Insulator from the hood and just leave the dynomat exposed...
    Another thing... You know where the front license plate would normally go? Just to the LEFT and RIGHT of this area, is a small space where a lot of people will install fog lights. I think this area is for air flow... am I right? If so, then maybe I should NOT fill those holes and leave them open for air flow..
    Any thoughts... comments on this???
    Quote Originally Posted by WILLY View Post
    I wouldn't think that the hood insulation would make that much difference IRT engine temp. Engine cooling is mostly determined by airflow through the radiator. Not much heat is dissipated through the hood anyway. The only real concern is that the Dynomat can hold up to the heat.
  1. winter button in heavy rain...........
    By IndianaVX in forum VX Talk...
    Last Post: 05/11/2006, 10:28 PM
  2. Heavy Duty CV Boot?
    By JULIAN911 in forum VX Talk...
    Last Post: 10/24/2005, 02:22 PM
  3. Heavy duty brush guard for VX
    By Jorge in forum Austin Robot Technology
    Last Post: 05/07/2005, 07:14 AM
  4. Stinkyfab Heavy Duty TieRods
    By StinkBug in forum VX Talk...
    Last Post: 01/17/2005, 09:33 PM
  5. VX heavy? Try this.
    By paultvx in forum VX Talk...
    Last Post: 09/12/2003, 12:08 PM
