Results 1 to 12 of 12
Thread: Low side A/C Hose leaking
    Nov 2008
    2001 Ebony Black VX #1301
    Hey all, looks like the low side hose for my a/c is leaking and needs to be replaced. Any good sites you recommend I look at to buy a replacement? Thanks!
    Nov 2008
    Nobody knows where I might be able to buy this part?
    Legally speaking, you must get a shop to do that. The remaining freon needs to be captured. Plus, after replacing the hose, the system needs to be evacuated before the new freon is added.
    In reality, you should be able to get a used one from most any boneyard. Ones from Troopers & Amigos with either a 3.2 or 3.5L should be the same.
    I have no idea where to get a new one.
    Mar 2012
    sold
    best bet to find one new is take it off, look for manufacturer or better yet a part # and then google that part number and ignore what car it says it goes to if its not a vehicross
    but tom is correct unless you have the equipment to evacuate then recharge the system you cannot do this at home
    Nov 2008
    I have a buddy that's a mechanic. I'm going to try to find a used one then, if the ones from the Troopers and Amigos are the same. I'll have the system recharged at a shop for sure. Any other Isuzus that might have the same part?
    Oct 2007
    2000 Victory White Ironman
    a/c lines
    I have an extra low and hi but the lines are for a DKV-14G compressor. Whats your compressor part number? To see if it will fit.
    Nov 2008
    Quote Originally Posted by KRemo View Post
    Awesome! Thanks! I'll look it up and let you know.
    Mar 2012
    sold
    i cant remember what the consensus was about the difference between the two compressors but if i remember correctly the connections to them should be the same either way
    May 2007
    1999 Black Rodeo
    The suction line (low side) connection is different between D and G compressors.
    --Dave
    Nov 2008
    I believe it's a DKV-14D Type Compressor in the Vehicross. Does this match up with what you have?
    Oct 2007
    match up a/c hose
    The dkv-14d has an angled top line so I'm not sure it will fit.
    Nov 2008
    I guess I need to start searching my local junkyards. Anyone know for sure what other cars have a matching system?
  1. coolant hose set
    By vxfocus in forum VX Troubleshooting...
    Last Post: 06/06/2013, 07:45 PM
  2. Moving the Steering wheel from Right side to left side
    By badsykes in forum VX Modifications...
    Last Post: 08/21/2012, 01:07 PM
  3. Side-by-side racing goodness!
    By ZEUS in forum Chit-Chat ...
    Last Post: 03/01/2011, 12:07 PM
  4. Looking for replacement whole right hand side automatic side morror
    By Crazy.T in forum JDM Parts & Accessories
    Last Post: 02/23/2008, 01:16 AM
  5. Breather hose?
    By thedutchguy in forum VX Troubleshooting...
    Last Post: 06/25/2004, 11:55 PM
