Results 1 to 7 of 7
Thread: Cylinder 4 misfire
    Jul 2013
    1999, Silver, Vehicross
    Cylinder 4 misfire
    First time poster. My 99 Vehicross (new motor) is throwing a cyl 4 misfire code and shaking like a muscle car. Were to begin?
    Feb 2010
    1999 Ironman,#1-1767, #2-1326
    change coils and see if stays on 4 first.
    Feb 2004
    '01 Ebony #0830
    Lightbulb
    I had a similar issue on my previous VX. Found that the wiring harness that feeds the coils had issues when I moved it around while the engine was running. It went away when I pushed down on it... so I zip tied it to the rest of the nearby harness. Problem "remedied". Worked fine until I sold it about 3 yrs later.
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Jul 2013
    I've tried switching #4 and 6 coils=same code
    Then I swapped #4 and 6 spark plugs and got the same thing
    Jul 2013
    I'm guessing this test cleared my spark plugs as being the issue. Injectors next?
    Nov 2007
    1997 SILVER
    Joe, don't know anything about your skills, but just check that you are counting your cylinder numbers correctly. There is a Service Manual on here that shows the layout.
    Other than that, yep I would go fuel injector, and then compression test.
    Good luck.
    PK
    When I had a "misfire" code ot was solved by cleaning the fuel rail.
  1. p0306- Cylinder 6 misfire
    By Grif in forum VX Troubleshooting...
    Last Post: 04/19/2011, 06:38 PM
  2. 3rd cylinder misfire = leaking intake manifold gasket
    By PHO2GR4 in forum VX Troubleshooting...
    Last Post: 12/30/2006, 12:28 PM
  3. Help Please- Cylinder misfire and Timing Belt
    By NC_VX in forum VX Troubleshooting...
    Last Post: 12/10/2004, 06:36 AM
  4. P0302- Cylinder #2 misfire
    By olsonjus in forum VX Troubleshooting...
    Last Post: 08/20/2004, 04:36 PM
  5. misfire in engine P0300
    By alexeikuchinsky in forum VX Troubleshooting...
    Last Post: 04/15/2004, 05:50 PM
